Go Back  RCU Forums > Electric Aircraft Universe > Glow to Electric Conversions
Reload this Page >
85" 50cc QuiQue YAK54 Outrunner Conversion
Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Old 07-12-2006, 02:01 PM
Sean Plummer
Default 85" 50cc QuiQue YAK54 Outrunner Conversion
A few Months ago I ordered the 85" QuiQue Yak54 (50cc) ARF http://www.somenzini.com/html/aircraft/yak85.html.
The goal was to power the model with a Single Outrunner System. The model was completed as per the instructions using Futaba equipment as follows:
Ailerons: S9152
Elevators: S9350
Rudder: S9351
Receiver:149DP
Receiver Battery:Thunder Power 2S-1320mAh (Duralite 6V Regulator)
The Power System uses the new Hacker A60-18L and Master 90 Acro ESC on Thunder Power 10s-8000mAh with a 26x15 APC-E Prop. The system pulls 85 Amps at full throttle. The all-up- weight of the plane is 17LBS.
ID:	490509   Click image for larger version
ID:	490510   Click image for larger version
ID:	490511   Click image for larger version
ID:	490512   Click image for larger version
ID:	490513   Click image for larger version
Old 07-12-2006, 05:17 PM
fbw4
Default RE: 85" 50cc QuiQue YAK54 Outrunner Conversion
I have one of these motors in my BME Edge and have been vary impressed with the performance. It’s nice that Hacker is producing outrunners big enough to power these large planes without breaking the bank.
Old 07-18-2006, 10:30 AM
Sean Plummer
We have about 40 flights on the model. This system flies the plane very well and provides enough power for 3D aerobatics and Pattern. The speed is lower than the typical 50cc but has unlimited vertical that is very solid. We have flown this model in many weather conditions including +103 degree weather, High humidity and High wind (25mph). Typical flight times are about 10 min with mixed full/part throttle.
Here is some video: http://www.rccraze.com/qqyak.mpg
Best Regards,
Sean
Old 07-18-2006, 03:17 PM
Mike Parsons
Mike Parsons's Avatar
I'd bet some purple paint that it was Mark @ the helm
Old 08-06-2006, 10:02 PM
MSP1957
Nice flying
Old 10-19-2006, 07:54 AM
didiwatt
My Feedback: (38)
Sean:
Nice set-up. Who makes or where did you get that motor mount that has a rear stabilizer plate? What kind of RPM's do you get with the 26x15 apc. I have a comp-arf 2x2 that will finish out at 15lbs and I was thinking about going the next higher kv on the A-60 cause I don't think I will have the prop clearance for a 26. Thanks in advance.
Paul Eagon
Old 11-07-2006, 01:44 AM
dorado
Hey Paul
That mount is available from Hacker...order it from them when you get the motor.
Dorado
Old 12-09-2006, 06:55 PM
bodywerks
bodywerks's Avatar
8,000 mah seems like a lot for a system that only pulls 85 amps WOT. I am considering electric on a 35%er and plan to use only 8,000 mah on 12 or 14S. I imagine that at 10 minutes flight time you are only using about 4,000 mah, no?
Old 12-05-2010, 02:00 PM
joshmoha
My Feedback: (75)
Default RE: 85
hey nice plane ...i need help ...i am going to have a toc extra 30% and what motor would i use and 10s but i dont have enough ground clearance...so what prop/esc/motor would i use???
Old 12-06-2010, 06:20 PM
joshmoha
My Feedback: (75)
Default RE: 85
how did you hook up both batteries
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
