Ultrasport 40 "Plum Crazy" Electric Conversion
Purchased this glow Ultrasport 40 from a club member with the intention of converting it to electric.
It appears to be constructed correctly, and the price of $60 wasn't too bad. Currently it weights 3.6 lb. I don't think the wing will need any modification. Most of the work will be on the fuselage. Right now, I am thinking of cutting off the nose back to the firewall, and making a motor extension box out of 1/4" plywood. Probably cut a hatch in the bottom for battery access. I see Fiberglass Specialty's makes a cowl, but I am not willing to spend the money on that option right now. I am going to have to find some Plum Monokote. It appears to be discontinued. https://cimg1.ibsrv.net/gimg/www.rcu...c51a84795f.jpg https://cimg2.ibsrv.net/gimg/www.rcu...91356c6528.jpg https://cimg7.ibsrv.net/gimg/www.rcu...6437d07cf3.jpg https://cimg0.ibsrv.net/gimg/www.rcu...ca563a7239.jpg https://cimg7.ibsrv.net/gimg/www.rcu...0ed2a7d267.jpg |
The dirty deed is done !
The deed is done. Sawed off the epoxy-soaked front end and sanded it smooth.
Cut a battery hatch in the bottom. I would have preferred to load the battery. from the top, but that didn't seem to be an option. he point here is just to make the plane fly. I will worry about looks later. https://cimg8.ibsrv.net/gimg/www.rcu...12f492de21.jpg https://cimg9.ibsrv.net/gimg/www.rcu...f0c616c753.jpg https://cimg0.ibsrv.net/gimg/www.rcu...717ed32904.jpg |
Motor extension / weight box
Motor extension / weight box ready for the arrival of the motor.
https://cimg7.ibsrv.net/gimg/www.rcu...17bb8d68da.jpg https://cimg8.ibsrv.net/gimg/www.rcu...efbd01f6b3.jpg |
In an effort to reuse the original nose from the airplane I had to redesign the motor mount.
The motor box was SOLID, but it was too big to fit into the original cowling that I had sawed off. I made this new mount using 3/8" aluminum rod and duralumin plate. Now I am gluing a plywood former to the back of what remains of the front cowling. and will soon be flushing out (with balsa) where the nitro engine used to stick out. I hung the lead weight discs with 3/8" "P" clamps from the hardware store. https://cimg9.ibsrv.net/gimg/www.rcu...79b76f80c1.jpg https://cimg4.ibsrv.net/gimg/www.rcu...641b968833.jpg https://cimg5.ibsrv.net/gimg/www.rcu...c87af8b5c5.jpg https://cimg6.ibsrv.net/gimg/www.rcu...fddab39835.jpg |
I had cut the original front end off of this bird with the intention of buying a plastic or fiberglass cowl.
Being cheap by nature, I decided to rebuild the original front end. I was able to peal all of the epoxy off the inside of the cowl, and I cut out the bad wood and white glued replacement wood in place. I traced a 1/16" plywood former using the front end of the fuselage, and put new wood in place where the engine cutout had been made. I would take hours sanding this by hand, but only minuets with my belt sander!! Almost ready to cover the cowl. https://cimg3.ibsrv.net/gimg/www.rcu...bd23ada36e.jpg https://cimg4.ibsrv.net/gimg/www.rcu...e87337fc67.jpg https://cimg5.ibsrv.net/gimg/www.rcu...678c19def8.jpg https://cimg6.ibsrv.net/gimg/www.rcu...7fd7b638c1.jpg https://cimg8.ibsrv.net/gimg/www.rcu...3527374aeb.jpg |
Here is the final (for now) result of the fuel to electric conversion of my Ultra Sport 40. I think the cowl turned out very nice.
With the combined weight of the cowl, and the spinner I was able to remove the lead from the nose. Thats a vintage 1980's Tru-Turn spinner I had saved from the 80's. I did fly the model with the wood motor box, and it had plenty of power, but was nose heavy. FYI, it is powered with a cheap 4250-800kv motor from China, 60-amp ESC, running on 4s 3300mah using a 12 X 8" prop. With a full charge, the system is showing around 750 watts. Looking forward to the next flight. https://cimg5.ibsrv.net/gimg/www.rcu...54c9afc880.jpg https://cimg6.ibsrv.net/gimg/www.rcu...1833bb1d07.jpg https://cimg7.ibsrv.net/gimg/www.rcu...21dcb3727e.jpg |
