RCU Forums
-   Glow to Electric Conversions (https://www.rcuniverse.com/forum/glow-electric-conversions-132/)
-   -   Chea-Pass (https://www.rcuniverse.com/forum/glow-electric-conversions-132/1453574-chea-pass.html)
skyblue 01-21-2004 06:00 PM
Chea-Pass
I converted a House of Balsa,Chea-Pass intended for a .01 gas engine.My electric version has a AXI 2808/16...8x5 electric prop...8-1100cp battery.The plane is all laser cut with interlocking parts,this makes for a very fast build.I used four hitec hs-55 servoes(REand2servos in the wing).The AUW=28oz.The wood supplied in the kit was very light but a bit fragle.I had to replace the rudder with a stronger piece of balsa.The landing gear platform ( another weak spot)needed some extra plywood in this area.I actually fly my Chea-Pass without a landing gear.The plane flies great,it will loop,roll,fly inverted and do outside loops with ease.I plan on getting another Chea-Pass and make some major modifications in the future.
skyblue 01-27-2004 02:07 PM
RE: Chea-Pass
Correction: The plane mentioned above is not the Chea pass but the Laser Stick.10 by House of Balsa.Chea pass refers to the "series" of aircraft by HOB of which Laser Stick is one.
Phil
