Sukoi SU26MXRG to be AXIfied!
1 Attachment(s)
After converting my Wide Body Super Kadet to electric,I have decided to put the 4130-20 on the Sukoi.I bashed a Goldberg kit to the following specs:
span increased to 80" Spring Air retracts Webra Speed 120 non-scale color sceme(I just wanted to make it different) There's a long story why the cowl&belly pan are missing in the following picks.The webra is getting older now and I'm more and more into electric now days. R.L.Karp, "Zooming around @ 8000'ASL":) |
RE: Sukoi SU26MXRG to be AXIfied!
I forgot to mention that this is the 3rd kit of this plane I've built in the past10 yrs.It flies even better with the gear up than the other 2 did and looks soooo cool in the air!Comming at you from a distance it looks like WWII fighter untill you can see the color sceme.Also burns a little less fuel with the gear up---less drag!If you don't compete in Scale events,why not.
