RCU Forums
-   Glow to Electric Conversions (https://www.rcuniverse.com/forum/glow-electric-conversions-132/)
-   -   rascal or nitro rascal? (https://www.rcuniverse.com/forum/glow-electric-conversions-132/5330164-rascal-nitro-rascal.html)
eric01 01-27-2007 09:25 AM
I was wondering if anyone had info on the differance between the nitro rascal, and the elec version, ( other than elec./glow). I am deffinately going electric, but already have a power system. The rascal(electric) comes w/motor & esc, and is nearly $100 more. Would the nitro rascal be an e-conversion candidate, or is it not worth the hassle? I don't need any more can motors, that's for sure.
drksyd 01-28-2007 07:16 AM
RE: rascal or nitro rascal?
Haven't seen the little ones but the nitro may be a little heavier. I would save some money and get the glo version. Most companies have motor mounts available or you could make a box yourself.
eric01 01-28-2007 11:11 AM
thank's drksyd. My thoughts exactly, just wanted a second opinion. I also came across a thread on wattflyer where someone did just that, using an E-flight stick mount. (I love E-flight products)
drksyd 01-28-2007 05:39 PM
Good luck with it. If you like the little one, try the .40 size, it flies great.
eric01 02-05-2007 10:31 PM
1 Attachment(s)
Well I finished her up, it came out pretty nice. I chose not to use the stick mount, because the front former was square to the center line, instead I built a small plywood mount to use the built in thrust angles in the glow mount. I'll try to include pics (it didn't work last time)
-pkh- 12-12-2008 11:28 AM
So how did that fly? I assume this is the .061-.074 version, right?
