RCM&E Matador 60 four stroke ??
My Feedback: (10)
Would anyone have any information regarding an engine (rotory valve four stroke, called the Matador 60) designed by Derek Giles, and presented in the British model magazine RCM&E??
I don't know the year or any other info. But it looks very interesting and I would love to have a go at trying to build one.
Thanks!
Andrew
Thanks!
Andrew
My Feedback: (10)
RE: RCM&E Matador 60 four stroke ??
ORIGINAL: blw
Andy,
It would be interesting to see what you have planned. I may have that issue.
Andy,
I am hoping the reprint of the article come with the drawings... will see in a few weeks when they get here. I later saw there is also a twin version of the same engine, and I think I will order those as well.
Its a horizontal rotary valve in the head style, similar to the Webra T4-40/60/80 design.
AJC
I has the complete plans of the Matador 60, both single and twin engine. The twin engine are not a real boxer engine such as a OS engine, more like as a Saito with the two connecting rods to the same crank pin and the extra camshaft to other cylinder.. The engine are the 4 stroke engine with poppet valve engine and the camshaft has the helical gear crossed to the rear drive shaft who are driven by crank pin. There are no casted parts, mostly machined by solid aluminium bar etc..
I has still not builded the engine of the plan.
Also there are no rotating valve as the webra engine with Aspin valve.
My Feedback: (10)
Nope, eyes are fine.
WHatever engine they have on the top right hand corner of page 73, of that 50th anniversary edition of RCM&E, it is most definitely a rear belt driven, overhead rotary four stroke engine. And, they call it the Matador 60 by Derek Giles.
If they (the magazine) put in a wrong photo, I would still like to know if this mystery engine is available for home building.
I dont know why, but I have always had a "thing" for belt driven rotary valve four strokes. I just think they are cool!
Here is a shot of mine, I built this about 7 years ago from scratch. I made a casting for the case. The rest is bar stock. Its a brute, but it was a proof of concept design.
and a shot of the case for scale
My Feedback: (10)
YEs, I guess depending upon the valve design. In my own engine, I had the intake and exhaust openings in the rotary valve separated and closed off from one another - but there was a period of (sorry I forget the number of degrees) time when both valves were open. I based my timings on the T4-40.
AJC
AJC
My Feedback: (10)
And certainly not the same engine as shown in the magazine...
Perhaps someone at RCM&E, in preparing the 50th anniversary edition, took the wrong photo for the caption?
I would still like to know what engine IS in the photo... but finding info on these model engineering projects from years past is like pulling hen's teeth...
Oh well - its fun to talk about it.
AJC
AJC
ORIGINAL: Kmot
From Model Engine News, photos of an engine titled ''Matador''
In the plan are 2 alternative: with or without contact breaker. No change in compression ratio both for gas or glow plug engine fuel.
The helical gear for this engine must be ordered from gear wheel manufactur, but can make own gear wheel as i did with homemade tools as here :
[youtube]http://www.youtube.com/watch?v=HcG9Eoyf9aI[/youtube]
ajcoholic, i did not knew about the other engine with rotary valve made by Derek Giles, really nice engine. [8D]
Can you have valve overlap in a rotary valve four stroke like in a poppet valve four stroke like a OS or Saito?
There must have been at least two different engine designs using the same name then.
ajcoholic, great job on the engine build. I love it.
ORIGINAL: earlwb
