SuperTigre G-90 Prop Size
I have a new G-90 and ran it yesterday. (Break in by the book) The break in prop is a 13x6 also the biggest prop the book says to use is a 13x6. This prop seems under size for this engine. I checked the RPM’s at full throttle 12000. (Not broke in yet) The spec says top is 16000 RMP’s. It’s a 3-D plane and I like using X4W props. I have a 14x4W to try but I think it will by undersized too. Also, do I make sure it is broke in w/the 13x6 before changing prop size?I'm using 10% Nitro, can't fine any fuel with less nitro.
I have the same engine on my hellcat. Check out this. http://www.quicktechhobby.com/articl...rt_for_two.htm
Looking at that chart a 14x6 or 14x8 would work. I was thinking of trying a 14x6. I see heat is a big deal along w/power band. But over RPM's will heat up an engine just as bad as an over size prop. Man this thing screems with a 13x6, just seems to much, even some of the other guys at the field said it seems to much.
14x6 or 8 seems wrong for 3D
Please read [link=http://supertigre.com/engines/supg0235-man.html]this article[/link] from MAN's Mike Billinton, and the prop sizes used.
Different strokes, hah?
Was born with it. Never turned any other prop.
http://www.youtube.com/watch?v=Y8-1i6Y4zYI
ST G90, Seagull Extra 300 .75
Well it's been awhile. I got out today and put a Master Airscrew 14x6 on and what a difference. This plan has all the power one could ask for. 10560 rpm high and 351 rpm low. When it gets broke in I will try a 15x4W or 16x4W.
Clair
I run a 14x8 APC in a Midwest CAP 232. It turns 9000 using 10% nitro. Flies the airplane very well, but I don't do 3D stuff with it. It turned 9500 with a 14x6. Handles the 14x8 well though, and the noise is not too loud.
Clair
Your engine is now making a respectable 1.466 HP. With the 14x6 it made less power, despite the higher RPM.
Please check the installation of the muffler to the stack... I suspect you may have it assembled 'too snugly', causing the 'drum' to restrict the gas-flow from the stack.
It has been mentioned by some that they cut the stack at a 45° angle, to prevent the drum from ever 'snuffing' the flow.
An MVVS .91 engine, on 5% nitro and with the #3250 pipe, makes an APC 14x8 spin at 10,500 RPM.
This is 2.328 HP and the improvement is much, much more than a tuned exhaust alone should add.
Clair
14x6 and 13x8 are the bench mark props in my neck of the woods. For 3D I would run a 15X4W APC.
david
