Too much prop stopping ENYA 60X ?
Prop load does have an effect on the mix. You need to retune for each prop, as the revs will be different, so will the peak mix.
ORIGINAL: Altered1
Thanks for all the input guys! Much appreciated. I'll take it step by step and see what I can come up with.
Question though - in my original post, I indicated that the engine ran for longer before cutting out once I fitted a smaller diameter prop. without a carb adjustment, does this have the effect of a richer mix ?
