if your glow engine was in your car
#76
AL
ORIGINAL: aspeed
Wow, this thread took on a life of it's own. I say chop it up unless it is historically significant? I am a Streetrodder from way back.
I have found that many fun things aren't cheap.
jess
#77
ORIGINAL: Farmer Ted
Wow, this thread is a little scary with misinformation.
A two stroke ''Glow'' RC engine is (basically) just a 2 stroke diesel.
A four stroke ''glow'' RC engine is (basically) a four stroke diesel...very similar (in principle and operation but without fuel injection) to the 4 stroke diesels in cars and trucks.
Diesel engines use the heat of compression for ignition, the glow plug is just there to provide an ignition source to get the thing started. In glow airplane engines, the glow plug does continue to act, to some degree, as an ignition source along with the heat of compression.
Gasoline engines use an electric spark for ignition and can be run with minor modifications on alcohol, natural gas, and most any other flammable vapor
Diesel method injects the fuel into the combustion chamber containing pre-compressed air, which is hot enough to initiate the ignition of the fuel-air mix (glow plugs are only for cool start).
Otto method compresses a fuel-air pre-mix (to lower values of pressure than Diesel's or auto-ignition would occur). The ignition is initiated by a heat source (spark or glow plug).
Hence, all the glow RC engines (two or four-stroke) follow the Otto cycle, just like all the gas engines (two or four-stroke).
http://en.wikipedia.org/wiki/Diesel_engine
http://en.wikipedia.org/wiki/Gasoline_engine
