K&B Sportster Club
NC
RE: K&B Sportster Club
Here are the ones I have
.28 that will be going in a scratch built Super Cub
.45 that will be going in a Sig plan built Sig Kadet Mark II
.65 will be ing in a scratch built low wing sport plane like the GP Super Sportsters.
I would like to use my pair of .65's in something good sized, probably a warbird or something slow since the engines are far from speed demons.
My running Sportster .65 got my flat bottom scratchbuilt airboat to 30mph on a 13x6 APC prop.. Due to carb problems and flameouts, I had to swap it out for a Super Tigre S90K.
The base of the S90K carb is .034" smaller than the .65 carb. Isnt that bizarre?
NC
ORIGINAL: 1QwkSport2.5r
Since this is a new club and I feel left out since I dont have a club member number in the Enya, Fox, or ST clubs... can I be #4 if we do member numbers? [8D] (I know it is of zero importance but I dont care.. lol)
I wasn't planning on doing numbers since this is a weird off shoot of the main K&B club, if there is one on RCU.
But ya go for it.
ORIGINAL: buzzard bait So what's the plane with the .65? Jim
http://www.rcuniverse.com/forum/m_10675544/tm.htm
Idid not put any more pics or info, because I did not want to hijack this thread. But that will give you the info on the plane. When it is done I will post another picture here THAT ALSO SHOWS THE ENGINE.
This post is a little behind in replying to you buzzard bait as RCU was being a real snot. I gave up and went to bed.
There were only 4 post on this thread last night when I gave up on RCU. Now there are 27.
Thanks for the clubAmish. Way to go
Wow, that is a real silk-purse-from-pig's-ear story! Nice work.
Yes RCU is such a pain these days I've been using RC Groups much more.
That plane should be a blast with the K&B .65.
Jim
Jim
#31
Now a technical question.
Does anyone know what size the .65 mffler bolts are?
My muffler ran away during one of many moves around the country.
I am having to extend my muffler out. I found my original muffler adapter, and bought a second. So I have to go to Fastenal and some longer bolts. I think they need to be grade six or better bolts. Again if any one knows what grade muffler bolts normaly are chime in. Hardware staore stuff is way to soft, they will strecht and then you got a loose muffler. Even more so in my case.
I have to extend a good inch. So that makes for 3.25" bolts. I am not sure if the one bolt shown in the pictur is an original sportster .65 bolt or if it was just in my bin. So I can't trust that it's threads are correct.
#33
Jim
Jim
I have been useing the other sites more and more but I have yet to do a build thread elswhere.
The plane should be a blast considering a .45 was just fine on it before, even with floats.
The sportster is less weight so less balance issues and I can prop more like a four stroke and not rip the wings off.
#35
Would you consider selling one of your .20's or do you still have plans of flying all 4 of them?
edit: Also, your .65 has the big head fins on it. Must be an early model. Most of the newer-than-'90 engines have the short machined head fins.
edit #2 (while RCU will let me): Since this is a new club and I feel left out since I dont have a club member number in the Enya, Fox, or ST clubs... can I be #4 if we do member numbers? [8D] (I know it is of zero importance but I dont care.. lol)
ORIGINAL: earlwb
I happen to have four K&B .20 Sportster engines and a .65 Sportster engine too. I had originally planned to use the .20 engines on a Royal B-17 I was building but the framed up plane met its end when I was moving and got crushed in the process.
They only have member numbers for the Saito Engine Club group. I think that no one else wanted to issue the numbers and track them for the other engine club groups.
Do you want to volunteer?
#36
ORIGINAL: earlwb
I wasn't planning on selling some of them, as I was still thinking about building a 4 engine plane sometime But thanks for the interest.
ORIGINAL: earlwb
#37
ORIGINAL: flyingagin
I think they are 6x32 screws. K&B wasn't doing much if any metric things with their engines at the time. Albeit they liked using the cc engine displacement moniker though. But I don't know if anyone makes them that long though. You might be able to use the 6x32 threaded rod and use long nuts. There is a special nut that looks like it is two or three deep, but one piece. I forget what they call it. I went to look for my engine to double check the muffler screw size but I can't locate it yet. it is around here someplace.
#38
6x32
thnak you earlwb.
I am going to be near a Fastenal later today so I will check.
The more I think about it the more I think the one bolt I have just might be an original .65 bolt.
I will check its thread size also.
thnak you earlwb.
#39
ORIGINAL: earlwb
ORIGINAL: earlwb
As far as numbers... I dont really care that much, but since this is going to me a somewhat limited group of people, (in terms of number of "members") I'd keep track if anyone wants a number since I think we might be a very select few that like these engines. Any thoughts, fellas?
#41
I wouldn't go to the trouble. Nice to have a place for knowledge and interest in these engines. That's enough.
thanks,
Jim
thanks,
Jim
#43
NC
It's amazing how RCU knows when you copy a post "It post right away" and when you forget to copy it ", doesn’t post and takes you back to an empty page.
#44
My Feedback: (149)
Hey all you Sportster fans,
Got 2 Sportsters, a 45 and 65. The 45 has never seen fuel. Many years ago built a Durabat and put an 40FP w\DDD head on it, . . . never could get it to balance so now it has the Sportster 45 on it. It did balance then, but still have never cranked it or flown the plane, . . . . I really don't like the slop in the control linkages.
When new the 65 was mounted on a Jeff Troy F16 trainer, . . . guess that was one of the 1st ARC's around. - it used a lot of Luan wood in construction. Have a pretty low opinion of that plane also, but did take it to be maidened once, . . . but on startup it got into my thumbnail & a couple of fingers, so that trip ended at the ER.
Both these were bought with budget constraints in mind, . . . and since bought DDD heads for both, thinking to make them act "bigger" with larger props. It's only recently that have begun to actually learn anything about the characteristics (thanx to RCU) of these engines.
As far as castor goes, also have a K&B 3.5 (with an extra DDD head), a Lee modded 61 - pumped with perry carb, HP VT25 & VT49, and RCV 60SP 90SP & 58CD, . . . all of which thirst for the stuff.
Have subscribed here & look forward to more learning & finding suitable airframes for mine and FLYING them.
T-man49 in Al
Club Saito 723
Mike Brennan
T-man49 in Al
Club Saito 723
Mike Brennan
#45
NC
Yeah it would have been nice to know that you had the Diesel running chectorisitcs built into the engines already. You basically just switched fuels with the DDD heads.
Hey if you don't mind, when you get those engines going could you do some test and see how the DDD's perform on the Sportsters? Prop sizes and RPM's would be nice. Scientific would be even better.
I was thinking about making a standard engine performance chart so if you guys want to post your test stand figures fill out as much info as you can so we can accurately compare readings.
Tom might get mad at his engine for not performing as well as Dicks, Dick didn't post that he lives in FL at sea level and ran his engine in winter at 40° outside wile Tom ran his engine in CO at 6,000 Feet during the summer at 90° temp.
Sportster club members, just coppy this and post with your data filled in.
Engine
Outside weather conditions,
Altitude............
Temp..............
Humidity.........
Prop,
Brand............
Style.............
Size..............
Pitch............
Fuel,
Brand............
Nitro..............
Oil................
Age..............
Engine Performance,
RPM........................
Head Temp..............
Exhaust temp..........
Engine
Temp..............
Humidity.........
Prop,
Brand............
Style.............
Size..............
Pitch............
Fuel,
Brand............
Nitro..............
Oil................
Age..............
Engine Performance,
#46
NC
How NOT to tune your Sportster.
Good video of a .28 on an Eaglet but they way he tunes that engine over the prop is just scary!
Any guesses to how close the prop is to the veins and arteries in his wrist?
http://www.youtube.com/watch?v=ME1lfpzoJRU
Please tune your engines from behind the prop. Your dealing with an oily plane that can unexpectedly lurch forward at any second.
#48
NY
I am a K&B fan. I have several of .20, .28, .45, .65. Non-Sportster .61, and a 1.00 with the box muffler mount. Looking for a plane for the 1.00. Love them and feed them castor. Anyone have a 1.00 running in a plane?
#49
I bet that would be a heck of alot of work. Picture me gimping away form that one.
ORIGINAL: earlwb
ORIGINAL: earlwb
The first one I sold to someone else. The second was shot down by a moron who turned his TX on while I had the frequency peg.
The third got killed when I was moving.
So I guess I'll have to bash something together nowadays.
Anyway if you have ever built a Royal kit you would appreciate the effort involved.
But there is something about four engines that just can't be beat for sound and everything.
