Testing the new NV (Norvel) .40 size (6.5cc) gasoline glow engine
#251
My Feedback: (149)
In spite of my grumpy attitude, I want to thank you very much for posting your very honest article and replies. Without your original post on this topic, the majority of us (we fellow forum members) might not have known about this engine's existence. Thanks again.
Ed Cregger
That Quote is from very early in this thread, and personaly I've seen nothing since that has made me feel any different concerning the OP. Have noted that there doesn't appear much difference in cost of fuel, but in a 40 size, how really important is that.
T-man49 in Al
Ed Cregger
T-man49 in Al
#252
merlin: http://www.merlinglowplugs.com/Aircraft.html also sells nelson style plugs as well as cox and norvel plugs for a decent price.
#253
ORIGINAL: hsukaria
Yeah, ''inexperienced'', I have gotten a lot of help from 1QwkSport2.5r too.
Anyway, I don't deny that this engine is good. But you have to realize in the real world, there is always a design compromise. But here, even if there were some slight performance loss (I'm not sure there really is, except that you have to run a bigger prop than the glow version), the cost savings are substantial. You are running $6/gal gas instead of $18/gal glow fuel. I would think that would make up for any drawbacks.
ORIGINAL: triumphman49
Zagnut,
Have you got a sling? Seems like you might need it after patting yourself on the back so hard.
1QwkSport2.5r , with 3500 post, if your ''inexperienced'' . . . . they don''t even have a rating for someone like me. LOL Have followed your posts in the Saito, K&B, and conversion forums and try to learn a lot from your experiences.
T-man49 in Al
Zagnut,
T-man49 in Al
I'm probably chasing a snake oil dealer on this one though.
#254
Wow, lots of stuff going on! Just for the record I contacted NV direct, not through Bill, they then emailed me to let me know the engines were ready. Ok, so I have some gas and will be trying to give it a test run this week.
Andy
Andy
#255
The claim made earlier in this thread is that the gas version has to run with a bigger prop at slightly lower RPMs. I have had a Norvel AX-40 for the past 5 years and used it as a general sport engine and now am putting it in a speedy plane that uses a smaller prop and higher RPMs. So, I would not want the gas version, since it is limited by the top end RPMs but is claimed to have higher torque. So, the gas version would not work for my present application. Conversely, according to the claims presented here, I would be tempted to use the gas 40 as a replacement to a 4-stroke engine, like a 52.
#256
Have to agree with you on the AX 40 for the small, fast planes. Light weight and high rpm. I use it where I used to use a 32 or 28 and really haul.
Do you know which tuned pipe header fits it? I have 3 for my 25 NVs that work great (got them off fleabay from an ex-racer) I know the 40 responds like the OS with the increased exhaust volume. I played around by making a 1" extension to fit between the front and rear of the stock muffler using a longer bolt and picked up another 1200 rpm with the small props, so thinking it would do well with a tuned pipe too.
#257
ORIGINAL: 1QwkSport2.5r
I have a hard time accepting that a gasoline fueled .40 will run faster than a glow .40 on the same prop.
#259
OH
Just 1 last thing can you use aviatition fuel or racing fuel in the oil blend if I can stay away from the smell of gas all the better.
#260
ORIGINAL: erieqc
Andy
#261
do you also have a hard time understanding that a .40 diesel will turn a bigger prop faster than a glow .40?
#262
Not really, but then again, I also believe the world isn't flat, a 747 will actually fly even though the wing is too small, space flight is possible (I watch launches from my front porch) and that black holes do exist.
#263
ORIGINAL: hllywdb
I have to agree with you on the AX 40 for the small, fast planes. Light weight and high rpm. I use it where I used to use a 32 or 28 and really haul.
Do you know which tuned pipe header fits it? I have 3 for my 25 NVs that work great (got them off fleabay from an ex-racer) I know the 40 responds like the OS with the increased exhaust volume. I played around by making a 1'' extension to fit between the front and rear of the stock muffler using a longer bolt and picked up another 1200 rpm with the small props, so thinking it would do well with a tuned pipe too.
If anyone has any other possible muffler solutions, it help me a lot.
#265
It kinda puts me off because for a glow plug to stay that hot, it would make sense that it wouldn't last as long. Hotter plug = thinner coil. It the wire gets too hot it'll simply melt. Gasoline burning that much hotter than methanol must drive a fine line between longevity and reliability. Being a turbo plug lends me to believe the Turbos are hotter plugs yet plus they seal better. Not my idea of a money saver since Turbo plugs are about $2-3 more than standard plugs at the hobby shop. If there is a spec sheet from Norvel available for this engine, or even the owners manual, I wouldn't mind seeing it. Any links to this or is it still hush hush?
ORIGINAL: Sport_Pilot
It doesn't have a catalytic reaction, it is simply reacting to the heat of the glow plug. The glow plug needs to be hotter. It retains heat to the next cycle. Much like a red hot exhaust valve causes preignition, only this is controlled by the heat range of the glow plug. See the gas/glow threads in the engine conversion forum, there is some success with pure gas and a really hot plug, or an on board glow ignitor..
I've read this thread on and off for awhile and I am still a bit perplexed as to gasoline working with a glow plug using a catalytic type of reaction like glow fuel.
#267
ORIGINAL: Uncas
Just curious. What is the ratio used of Gasoline to Klotz Benol?
From the discussion above 1 part Benol to 4 parts Gas or 20% total Klotz.
But as I pointed out above the Benol spec sheet suggests that Gasoline will dissolve only 6.25% Benol by volume at normal room temperature.
An interesting suspension of the laws of Chemistry?
(Pun intended)
#269
been referenced here as 14% . . . . . a pint will make about a gallon
which post number?
Ray
#270
And Just for us curious types, how is it difficult to believe that the gas engine can produce more power than the Methanol based fuels, considering that gasoline has about 45.7 MJ/Kg of energy VS Methanol at 22.03 MJ/Kg energy? By my calculation, that is a little over double the potential energy!! Granted, the gasoline must be run at a much leaner fuel/air ratio for proper combustion, but I still don't see why there might be some advances that would allow a gasoline powered engine to be of equal (more or less) power of that of a glow (methanol) fueled engine!
Craig.
Craig.
#271
qazimoto is corect. It won't dissolve higher than 6% or more. Can't go higher than that in a VRO or oil injection system as it won't disolve fast enough to burn it. Have to mix it, give it more time to disolve, then mix it again. Technical caster takes even longer, about a week. Benol has addatives to make it mix better with gasoline than stratight castor.
#272
look at the fuel/air ratios for each and you'll see why methanol makes more power by a very healthy margin....and that's before you start jacking up the compression ratio to way beyond what gasoline could ever hope to handle....but then of course if you add pixie dust and condensed unicorn farts to gas then all sorts of magical things can happen!
#273
ORIGINAL: hllywdb
You can order a straight out muffler from NV. I'm using one on mine.
#274
ORIGINAL: ZAGNUT
#275
Not if you get a cold enough plug on the glow engine. It is the fact that you are changing timing when changing the compression that does this. The timing for glow is from changing the glow plug, so unless you use spark ignition this is difficult to get the right timing. With complete timing adjustability then methanol will have more power and torque than gas or diesel fuel. But not very efficiently.
