90 degree elbow extension?
I've searched and I can't find what I'm looking for, hoping somebody else has done what I'm trying to do. I'm scratch building my own low wing design and mounting an ASP .61 upright , but I want to drop the exaust below the bottom of the fusealage. Normally I would just mount the engine at 45 or 90 degrees to do this, but in this case I want to keep the engine upright. Too long a distance for an exhaust extension alone to do the job, unless I make my own. The only muffler adapters I can find just rotate the muffler port 90 degrees. I don't want to rotate the port, I want keep the longitudinal orientation of the stock muffler, I just want to use a 90 degree adapter to drop the muffler about 1 1/2" below the cylinder port or else an extension on the muffler exhaust that can drop about 4". Not too concerned about weight as long is it is not more that a few ounces. Any body got other ideas or know where to get the adapter I want?
