Super tigre G60 info wanted
Old 05-07-2013, 05:37 PM
Scota4570
Default Super tigre G60 info wanted
I picked up a brand new, NOS, Super Tigre, G60, serie X. Never mounted or run. Even the prop nut is perfect. It is a blue head, ringed. Made in italy. The box is the hues of blue motife. The little Super Tigre plastic bag with the needle valve and muffler adapters/screws it there. The original packing paper is there. The only things that detracts is that the instructions are not present and the box has some light scuffing.
Is this a runner or a collectable? If it has significant value I would sell it to a collector and buy something I might use.
Scot
Old 05-07-2013, 08:16 PM
jeffie8696
jeffie8696's Avatar
Default RE: Super tigre G60 info wanted
Not a common engine, Ihave one thats missing a few parts and they are hard to come by.
Old 05-08-2013, 04:34 AM
spaceworm
ORIGINAL: Scota4570
Scot
Maybe this will help? Good luck.
File Type: pdf
File Type: pdf
Old 05-08-2013, 04:37 AM
controlliner
controlliner's Avatar
It is a good collector....but it is also a good runner.
Old 05-08-2013, 06:09 AM
Bax
ORIGINAL: spaceworm
ORIGINAL: Scota4570
Scot
Unfortunately, those are not the correct instructions for the SuperTigre G-60 the OP is asking about. His G-60 is the old Bluehead, which originally came out in the late 1960's, early 1970's. Instructions for that engine just are not available. The ones posted are for the G-61 engines that came out in the 1990's.
Old 05-08-2013, 06:18 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Someone on this forum has the paperwork for that engine I'm sure. If the OP doesn't get any hits with this thread, try Club Super Tigre thread. There are many people subscribed to that thread.
http://www.rcuniverse.com/forum/m_51...63/key_/tm.htm
Old 05-08-2013, 08:56 AM
Sport_Pilot
Sport_Pilot's Avatar
He said it was a G-60X and I believe that is quite a bit different than the old G-60 bluehead, though it still had a blue head.
Old 05-08-2013, 10:02 AM
MetallicaJunkie
MetallicaJunkie's Avatar
isnt that the series Hanno Praetner competed with?
Old 05-08-2013, 10:33 AM
turbo.gst
My Feedback: (8)
I thought Hanno switched to Super Tigre with the S-series( in the 80's). In the 70's when the ST X-series and the Bluehead G-60, Hanno was using the Webra Speed#1024.
Old 05-08-2013, 12:26 PM
Sport_Pilot
I think this was the prior X version from Hanno's. Not sure if it was rear exhaust or not, may have been STS porting. I have one with side exhaust and STS porting, flat top piston and hemi head, but the thing doesn't idle that great. I don't think it is marked as anX model.
Old 05-08-2013, 01:51 PM
fiery
The "X" is a different engine
If anyone has a bolt-through muffler for the G60 Bluehead they would be willing to part with, please PM me.
Old 05-08-2013, 02:08 PM
turbo.gst
My Feedback: (8)
I have the G-60 series X ( .60) in both side and rear exhaust versions. I forgot that ST had an X-61 rear exhaust version during the S series of the 1980's.
Old 05-08-2013, 04:25 PM
jeffie8696
jeffie8696's Avatar
Mine is side exhaust.
Old 05-08-2013, 05:46 PM
Scota4570
Maybe pictures will help? My question is whether to "flip" it or not. If it is highly collectable I would hate to throw that profit away or mess up a collectable. I collect other things, pristine mint condition commands premium prices. If I run it the value would be reduced? Anybody hazard to guess at an EBAY value?
ID:	1880343   Click image for larger version
ID:	1880344   Click image for larger version
Old 05-08-2013, 05:50 PM
Scota4570
What the heck, those pics are terrible! Do over.
ID:	1880346   Click image for larger version
ID:	1880347   Click image for larger version
Old 05-08-2013, 06:31 PM
jeffie8696
jeffie8696's Avatar
Looks like mine , except for mine missing parts and the head color is faded.
Old 05-08-2013, 07:50 PM
proptop
My Feedback: (8)
proptop's Avatar
I bought one a few years ago, similar to yours, except mine has the natural Aluminum head....got it for $125.00 with no box or instructions.
There has been some increased interest in the older 10cc sized Pattern Ships and engines lately...
Just a WAG but your Blue Head might go for 150 to 175.00? Maybe a bit more...depending on who happens to catch your auction...? If it gets into a bidding war...then who knows!
Some of the guys in the "Classic Pattern" forum might have a bit better idea as to it's value...
Old 05-09-2013, 03:58 AM
EyeflyRC
My Feedback: (147)
The current series muffler and manifold for the ST .61 fits the ST .61 Bluehead, it has the same bolt spacing.
Old 05-09-2013, 05:52 AM
Bax
OK, it's an old SuperTigre X-60. They were originally made in the mid-1970's, when Schneurle-ported engines started coming out. Not a G-series at all.
Old 05-09-2013, 06:08 AM
controlliner
Tha last image has indications of the engine being run. The piston should be pristine semi mirror appearance to the skirt. It seems to have the usual vertical "telltale" burnish pattern of an engine which has been run.
Old 05-09-2013, 06:42 AM
1QwkSport2.5r
ORIGINAL: controlliner
Tha last image has indications of the engine being run. The piston should be pristine semi mirror appearance to the skirt. It seems to have the usual vertical ''telltale'' burnish pattern of an engine which has been run.
Unless its how the flash lit the engine, I agree it looks run. The piston ring should be black if unrun. Silver color if run in.
Old 05-09-2013, 08:09 AM
proptop
My Feedback: (8)
proptop's Avatar
I took a look at the pics last night, but didn't blow them up to max size...(until just now )...I agree...it does kinda look like it has been run....the ring and piston have that look about them...
That'll knock the price down somewhat...my above WAG was for un-run...
There is definitely a collector value to these engines, but there don't seem to be as many guys going after the Super Tigre engines, as some of the other makes...
I thought I got a good deal on mine at $125.00...but mine has not been run.
On virtually every new, never been run S.T. engine I have, or I've seen, the ring has had a dark gray, almost black appearance. When run, this wears away, and the ring becomes burnished, and the ring will look very similar in color to the piston...which is what it looks like in your picture...(could be just the lighting and/or camera angle though? )
Even if there are no "wittness marks" from washers or screw heads on the mounting lugs, it might have been run in a clamping style test stand?
They are nice running engines...you would probably enjoy using it yourself...even if it's never been run, I doubt that it'd bring much more than a couple hundred at best? They are rare (everything on epay is "rare" ) but they aren't what you could call "super-rare"...
Old 05-09-2013, 07:39 PM
Scota4570
The stuff on the piston is oil, I put a little squirt in there.
ID:	1880690   Click image for larger version
Old 05-09-2013, 10:39 PM
fiery
This is an ST - G60 "bluehead", a cross flow engine with an 8 bolt cylinder head.
Pics show it as given to me, coated in crud. Underneath, it is in good little used condition.
Is there an after market muffler that will bolt up? That is all it needs, as well as a decent prop washer.
ID:	1880713   Click image for larger version
Old 08-19-2013, 08:25 PM
jeffie8696
jeffie8696's Avatar
To me that old X60 looks like it should be a smooth runner.
