Large glow engines - are they passing away?
#277
This is good to know, but for how little I use I can't justify spending $60 on a gallon of oil. If I were to do that I'd be using Motul Micro or Aerosave/Aerosynth at $75/gallon. Castor works just fine in my four strokes; the mfg. specs castor oil or high quality synthetic blend. I know YS don't like gooey oil, but I don't own any YS engines.
#278
My Feedback: (13)
MN
Right now other than on OS32SX in a delta speed plane, all of the glow engines I am now using are YS 4 stroke engines. This is why I would need the synthetic oil.
What is the problem with Klotz KL-200, that you would use another brand of oil?
Greg
Greg
#279
n They would sell clear Ucon oil about 5 years ago and was said to be the same oil in all of their fuels. It was about $25 a gallon, I guess those colored dyes are expensive.
Nothing wrong with KL-200, except the price. On this site Coolpower oil is only about $30.
http://www.bmikarts.com/Oil-Methanol_c_214.html
Alcohol and gas make a different sound on full scale race cars as well. Alcohol makes the same engine growl with a lower pitch and always sounds better.
#285
As I understand things, some of the Klotz oils contain a percentage of Castor.
Castor, being gummy, is bad news for the delicate regulator/Non-return valve of some YS engines.
#288
IL
The sad fact is, in my area, hobby shops are closing. To run glow, I end up driving 1.5 hours round trip to get it. To those that would say mix up my own, I say it's cheaper and easier to mix up some 50:1 gasoline. I have a feeling all glow engines will become an expensive novelty as years go on.
#289
My Feedback: (13)
MN
Everybody use to call it "Cruel Power". I think it got that name because it didn't have any of the castor in it that most fuel had in the old days.
People didn't know how to adjust their engines properly and burned up a few because of the lack of castor that was saving their butt before 100% synthetic.
Greg
Greg
#296
You don't need castor in 2 stroke engines.I have been using cool power for 12 yrs never had an issue using in abn engines,abc,and ringed.If you have a problem tuning your engine then get someone who can teach you to set up properly.If you are using castor and synthetic blend you will still cook an engine eventually if not tuned properly.Pros and everyday flyers have been using cool power for years with great success.Synthetic is the way to go keeps the engine running at optimum performance ,keeps the engine clean and you won't have to clean that old sticky gummy castor off your plane.If you are using older engines from yesteryear yes continue to use castor if newer engines go with synthetic you'll be a much happier pilot .
#297
Engines are engines. Some castor blended with synthetics still provide better protection than anything else. There's no way around the fact that synthetics protect only to a certain temp, and then turn to ash. And, operator tuning isn't the only thing that will cause an engine to start running lean and hot.
#298
"Gassers" have a 2-stroke sound like weed eaters.
