Thunder Tiger 15 won't run!
Old 09-14-2014, 06:59 AM
telmore
Default Thunder Tiger 15 won't run!
Whatever I try....
Does this backplate wear look excessive to you?
Annette
Old 09-14-2014, 07:29 AM
init4fun
init4fun's Avatar
Originally Posted by telmore View Post
Whatever I try....
Annette
Yes , that is one sad lookin backplate ...
If it has no or low compression , it's a likely result of all that missing metal grinding the piston/liner fit all to heck ....
Old 09-14-2014, 07:42 AM
telmore
Thanks for the response.
Piston and liner and comp seem fine.
But I have pulled the engine apart but could not get the conrod big end off the crankpin.
It seems likely the crankshaft and/or bearings are not seated properly.
How about a thicker backplate gasket which may allow the engine to run and the bearing to seat properly?
Gannett's
Old 09-14-2014, 08:04 AM
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
I don't own a Thunder Tiger .15 but I believe they are "plain bearing" engines.
If the engine is a "plain bearing" or "bushed crankshaft" no ball bearings....there should be a thin washer behind the propeller drive hub. If this washer is missing it will allow the crank shaft to contact the back plate. It looks to me like the washer/spacer may be missing.
Old 09-14-2014, 08:17 AM
RCPAUL
Old 09-14-2014, 08:23 AM
telmore
Here are some pics of the complete unassembled engine.
I have now got the piston out.
The washer behind the prop driver is there.
What would be the best bet - to clean up the backplate with some emery cloth taped to something flat - or to fit a thicker gasket - or both?
I think I've been lucky as there seems no other damage.
Annette
ID:	2031818   Click image for larger version
ID:	2031819   Click image for larger version
Old 09-14-2014, 09:01 AM
jeffie8696
jeffie8696's Avatar
What fuel?
Old 09-14-2014, 09:06 AM
telmore
20% castor, 10% nitro
Old 09-14-2014, 09:10 AM
jeffie8696
jeffie8696's Avatar
That should be perfect. I would just go back to the basics, glow driver good and hot, proper prime, etc. I have run in to engines that do not like electric starters, you may want to try just manually starting this one. From the looks of the backplate this one may just be one of those.
Old 09-14-2014, 09:29 AM
telmore
90% of my attempts at starting were by hand including the first.
AFAIK this engine had no appreciable running when I bought it.
Old 09-14-2014, 11:23 AM
Mr Cox
Mr Cox's Avatar
Ooops, looks like someone has been grinding away with an electric starter on it...
You need to check how much the crankshaft can move back and forth with the backplate on, you can leave the cylinder etc. off for this test.
Here are two images of the same motor, first when the crank is pull out as much as possible and the second when the crankshaft is pushed in as much as possible (and crankpin hits the backplate).
The washer will (or should) rest against the small ridge on the crankshaft, and as visible in the second picture this ridge should have to pass the front bearing surface before the crank pin hits the backplate. If you don't have a washer it still works as the propdriver will also rest against the same ridge.
I can't actually see any washer in your pictures above, I can only see a washer for the prop nut.
My engine didn't have any washer either but you will need at least a thin brass washer there if you want to use an electric starter, you cannot let aluminum grind onto aluminum in the front.
ID:	2031871   Click image for larger version
Old 09-14-2014, 11:33 AM
Mr Cox
Mr Cox's Avatar
As for the starting problems I would check the carb retaining bolts, they can easily strip the plastic carb and they you get major airleaks there. Try an 8x4 prop and 5-10% nitro, plus 20-25% all castor. If the engine has compression, a good glowplug and some fuel it will always fire...
Old 09-15-2014, 03:37 AM
ffkiwi
I dare say an OS washer for a 10/15/20 will fit-you can get these as an individual spare, if a proper TT one proves elusive..... [dependinging in the measurements of the shaft and crankcase nose diameters] As an alternative-and requiring the same data-modelfixings.co.uk do a nice line in shim washers, in sizes from 0.1mm thickness up. Somewhere in their range you should find something suitable...and they're in your neck of the woods, so to speak....
ChrisM
'ffkiwi'
Old 09-15-2014, 04:04 AM
Mr Cox
Mr Cox's Avatar
It is quite easy to just make a thin shim from thin brass sheet metal, in order to avoid aluminium rubbing against aluminium. I have one mine for that reason, do a rough cut first then use a dremmel for the center hole and a pair of scissors for the outline...
Old 09-15-2014, 04:28 AM
ffkiwi
I'd rather use a lathe and do it properly without worrying about burring-and the lathe gives you the ability to do whatever custom thickness is appropriate for the engine....
Old 09-15-2014, 05:58 AM
Mr Cox
Mr Cox's Avatar
Yes of course a lathe is the best tool, but not everyone has the access or the ability to use one. I only have a hobby lathe myself, but it is good enough for making smaller things in soft metal.
Starting from sheet metal, one can however make these things without a lathe. Deburring is made on a piece of emery cloth on a flat surface (e.g. glass).
Old 09-15-2014, 06:05 AM
aspeed
aspeed's Avatar
Or a paper punch and scissors if it is thin enough. I use a protractor with a knife on the one point for thin head shims too. Sometimes a glow plug washer will work, depending on the size needed. It is usually easier to start a motor upright if that pic is what you are using. The fuel tends to drip out of the carb and doesn't get wet enough. Or start it with the plane upside down. I never had much luck with the smaller TT motors myself, but they usually do work to some extent.
Old 09-15-2014, 06:28 AM
Mr Cox
Mr Cox's Avatar
Just to clarify, I took the front end my engine apart and photographed it upside down in order to help the original poster...
The engine runs fine, the one issue that I've had is that the carb retaining screws will come out so that is something to check for the OP.
The engine gives around 13500rpm on an 8x4 prop and around 15000rpm on a 7x5 prop. The low end is very rich, even with the airbleed fully out, so it might work better with an idle bar plug (I haven't tried that on this particular engine yet though).
Old 09-15-2014, 10:12 AM
telmore
I've had a tankful through it now!
With an extra gasket at the back and an OS carb instead of the plastic one.
Looks hopeful!
Needle was open nearly 7 turns...
Annette
Annette
Old 09-15-2014, 10:55 AM
aspeed
aspeed's Avatar
Mr. Cox, sorry I thought it was the OP pics. 15,000 rpm is good, better than my newer style one. Glad to hear it is working for Annette.
Old 09-15-2014, 11:14 AM
flyer7007
My Feedback: (20)
Hello all I have been reading this thread and very rarely have anything to say. I have been flying R.C for about 45 years. and have a lot of experience with these small temperamental engines. After seeing the back plate all that metal went some where and you will find out when you think it is fixed. I personally ,and this is just my opinion and am not saying anyone is wrong or has given bad advise. I would take the motor, clean it up and put it on my desk as a paper weight. buy a new OS 15LA and go fly. have a great day.
Old 09-15-2014, 11:38 AM
Mr Cox
Mr Cox's Avatar
Yes, one could even use an electric contraption instead of an engine, but where is the fun in that?
It is a hobby after all and running the engines is a major part of the fun, as I see it. There is nothing temperamental about these engines, they just need the correct fuel and prop and then they run as good as any of the larger ones. Plus a well treated lapped engine will easily outlast the fragile nickel coating that OS uses, but that's another story...
Old 09-15-2014, 06:13 PM
downunder
downunder's Avatar
Those shavings probably aren't going to cause too many problems (if any) because it obviously uses a cast iron piston in a steel liner and there's no ball races to worry about. What intrigues me though is the pattern of that backplate scoring. I can't quite figure out how a flat ended crankpin could cause those ridged scores.
Old 09-18-2014, 02:43 AM
khalif
If everything was cleaned properly there should be no problems, the scoring on the backplate is strange. I don't think an extra gasket on the back plate is a good idea, this will reduce crankcase compression. The endplay in the crankshaft should be reduced to a few thou with washers/shims and then it should be checked that there is no contact between the crankpin and the backplate.
I have several TT15s and the 7 turns on the needle is also strange, both of mine are around 3 turns and the idle adjustment was OK. I just noticed it was not an original carb, I had probs with the carb on one but a new set of seals sorted it. Original carbs are about $25.
Old 09-18-2014, 03:33 PM
74SEVEN7
In the photo showing the cylinder liner, I'm curious as to what that hole is, just beneath one of the cut ports ?
