Saito 90TS twin bearing size
Hi,
I need to replace the bearings on my twin.
The manual says there are three bearings
Front
Main
Rear
Any idea of the sizes prior to disassembly?
Boca, only supply two for this engine?
A 608 and 6901 bearing.
Steve
Front
Main
Rear
Steve
For anyone that may need to know in the future. I disassembled the engine and removed all bearings.
Front bearing.... NTN 698 LU
Middle bearing.... NTN 6802 ZZ Note: there are two of these side by side.
Rear bearing.. NTN 6901ZZ
Rear cam bearing size is......8x14x4 millimetres.
Front cam bearing is ..........,.5x11x4 millimetres. No numbers on the cam bearings.
Regards
Steve
Regards
Steve
