OS 7D ball link replacement
Old 11-09-2014, 07:44 AM
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
Default OS 7D ball link replacement
I am in need of a plastic ball link for the carb arm. OS discontinued it quite a while ago. I once used a Dubro link, but do not remember which part number it was.
Old 11-17-2014, 12:26 AM
Ray Wasson
Buy a 2-56 ball link and pop out the ball. It should fit perfect. I used the Dubro for years.
Ray
Old 11-17-2014, 08:37 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
The issue here is that the ball link is metric in size, most likely 5mm ball dia and 3mm thread size, it is longer then a normal ball link and has a bend to it. I would suggest looing into some ball links used in helicopters, especially the ones used on the rotor heads. Often these were longer and metric sized. Although straight, they could be bent and may make a suitable replacement. I originally read the post wrong, if I'm not mistaken again, any 3/16 ball link should work or once again, check into Heli ball links for the plastic part of the link.
Old 11-24-2014, 06:47 PM
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
I just need the plastic part, and the dubro part # 367 2-56 ball link housing fits perfect.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
