How do I remove dried castor oil from an engine?
just last weekend I received two trucks with stuck engines due to years of storage with fuel residue. The engines were completely stuck as were the carbs. I wish I had found this post earlier but my only solution was using a typical carburetor cleaner and spraying it through the exhaust and through the carburetor into the engine then letting it soak. Within the hour the engine was moving. The piston ring took a little more to free and required me to remove the glow plug and throw some cleaner in there.
These are fairly modern engines (Traxxas and Team associated) but they now run normally without issue. Based on what I am reading here, I could have damaged something, I guess I am lucky.
regards
regards
Generally, an engine stuck from storage for a long time most often will only need a little heat and some glow fuel inside to loosen up. Petroleum solvents will break down the seals and such not to mention could take out the glow plug (or cause other problems) when trying to start. Carb cleaner is a scary thing due to its flammability IMO.
I know this is an old thread but what I do is boil a pot of water, take if off the stove and then dunk the engine or the carb, whatever you want to free up, and in seconds, the old oil is melted and you are off and running. Don't burn yourself......
I just spray it on without water, and use a toothbrush. It works pretty good. Some of the carboned up stuff doesn't want to come off. I have been thinking of doing it the redneck way. A vibrating sander with a sealed metal container bungeed on. It really works pretty good without it though. I still have some of the Dawn Power Dissolver too. I have walked by the U Sonic cleaner at Harbor Freight, but passed. I really don't have any more dirty engines except two really old ones. Do those videos make you any significant money? I wonder if I should bother.
I have been using the crock pot antifreeze method, I was tempted to get parts washer / cleaner but it seemed like a lot more for something I would not use often. My main concern with water based methods was residual water that could be left in ball bearings that could cause rust. I have been using brake cleaner to clean after soaking. Is my concern about the water valid? Is anyone using parts cleaner or find a source for it cheaper?
#32
NE
I use Power Dissolver on engines and in the kitchen, but I haven't been able to find it anywhere lately. I wonder if it has been discontinued.
#33
I like the LA Totally Awesome cleaner from the Dollar Tree. Only $1.40 and is concentrated and works well. Maybe the Dawn is a bit more aggressive, but more caustic, much like a BBQ cleaner. I just use the crock pot antifreeze on nasty mufflers and pipe to get inside carbon out.The Dawn stuff seems to have changed from a household cleaner to an industrial cleaner, so I would not bother looking for it any more. I am glad I got three bottles though as sI use it as a first choice.and then the LA Awesome stuff.
#34
Depending on what I’m cleaning, I use different cleaning agents and methods.
My favorite is Dawn Power Dissolver. Spray on, let sit 10-15min, scrub with a toothbrush, rinse and dry.
Barkeepers Friend cleanser, a little water, and a toothbrush. Scrub, rinse, dry.
LA’s Totally Awesome. Same process as Dawn Power Dissolver except it may need multiple sprays with cleaner to lift/soften the grungy stuff.
Antifreeze in a crockpot. Low heat, green antifreeze, 6-8hr soak. Rinse and dry.
Rust removal - Evaporust. Soak for 10-15min minimum. Rinse and dry, and oil immediately once dry.
Any of these methods or others mentioned will require oiling of Ferrous parts to prevent rusting.
#36
It’s not discontinued. It’s just not sold retail anymore. You can find it through janitorial supply companies and Amazon.
Examples: https://www.pjpmarketplace.com/dawn-...iABEgKog_D_BwE
Or https://www.amazon.com/Procter-Gambl.../dp/B00PRACR7W
