O.S. 1.08 ......I need a way to connect to the throttle arm on the carb.
My Feedback: (14)
AL
I just acquired this engine and it runs great... I have a small problem... The carburetor throttle arm is a ball joint that looks like it came with the engine new...? It is a large ball and I have very little space to connect it to the throttle servo....on the airplane..., as I have a muffler in the way... one small opening between the muffler and the engine... I need to make something like a z bend connection due to the space ... but there is no way to connect even if the ball joint is removed as the ball joint screws into the carburetor directly... there then is nothing to connect to..
Has anyone run into this set up and how can I make a simple connection...? the nylon connection arm for a ball joint will not slide between the engine and the muffler, a pitts type muffler....
Thanks, Richard...
Thanks, Richard...
The Heli guys have plenty of ball links that will fit the OS 108 ball on the carb. I was in your shoes once and took the engine to hobby shop measured the link and bought a pack. I have plenty now
