After run oil
AR
After run oil
Will 10W turbine oil make a good after run oil for 2 stroke glo engines?
https://www.mcmaster.com/#turbine-oil/=19yeqme
or this:
http://www.highsidechem.com/zoom_spout.html
or this:
I'm sure it would work but you would want to remove that oil before starting,,, so for week to week usage between starts you can buy a 2St oil (cheaper) that will mix with alcohol, try Klots..
for winter use or longer storage ATF is made to hold up well to friction and it wont gum like other oils will
Jim
Jim
Just between me and Fly my super secrete recipe is 1/3 kero , 1/3 atf and 1/3 oil that u normally mix in your fuel . The remaining add what u want !!!!!!!!!!! Dont tell anyone .
AR
Thanks for the reply Jim. Those 4 oz bottles with the extended tube are so convenient for oiling I had hoped that the oil in them would work. I will empty it and put Risilone in it. You don't have to clear out the Risilone before starting unless you really have the engine loaded up. I have used Risilone in my competition motors with good success for years.
I use ATF myself. $3-4 a quart and lasts forever (generic store brands are super cheap). I do NOT drain it out of the engine and flush it before firing it up. I prime the engine like I normally do and fire the engine up. Keep the glow driver connected and rev the engine a bit to clear it out. Works like a charm every time.
If you use oil that costs more than $5 or so a quart, you have expensive taste or are just wasting money. The engine doesn't care what kind of oil you use though.
My Feedback: (102)
I have been using this Corrosion X in a pump bottle since 1990 except for a short time I used NAPA Sea Foam. I drilled the spray nozzle out to slightly smaller than the diameter of brass fuel tank tubing and forced a piece into it. I have about 16" of fuel line attached to the inserted brass tube with a bulk head fitting on the end. It pumps CX into an engine with little to no effort. I go,through two bottles a year.
You have to be very careful with after run oil because the wrong oil can ruing the fuel lines and seals. I used KMart air tool oil as a cheap alternative to the after-run oils made by the hobby industry.
BTW, if it says it's good for gasoline engines DON'T USE IT.
My Feedback: (102)
I have experimented with the CX, it has never effected the 16" piece of fuel line I use on it and I laid a YS regulator diaphragm in a puddle of it for six weeks and it had no effect on it either.
The only thing your going to get agreement on is that using something as an after run oil is good practice. As far as what is used you could not know the varieties or concoctions that people use.
The trick is to use it often and for that to happen you must have confidence in the oil/mixture you have chosen.
SO grasshopper choose wisely.
Dennis
Dennis
I run the engine completely dry, then use ATF (automatic transmission fluid). I don't flush it out; just fuel and start as normal the next time. I have an ancient FOX .78 and a Fox .25 that have been flown and treated this way for 34 years. They have never been apart since new, and still run perfectly.
AV8TOR
AV8TOR
My Feedback: (29)
I have tried a lot of different stuff over the years. The problem is that many oils get gooey or even stiff like castor after a while. I keep finding that ATF is the thinnest oil that never gets stiff in the engine during storage. Turbine oil "ester" usually wont hurt silicone but will dry up over time, 0-20 Mobil 1 isnt too hard on silicone but got stiff after a couple of years, same with airtool oil. WD40 and most thin spray oil will last a couple of weeks before it dries up. My starter gets more use distributing after run than it does actually starting engines.
AR
After Run Oil
Thanks Kweasel and all others who responded. I guess I will not take any chances with the turbine oil. I will dispose of it and fill the bottle with Rislone Engine Treatment Concentrate. I know it works. I have used it for the last 15 years without a problem, even with some engines that hadn't been run for 8 years. These are free flight and CL combat motors (K&B, CS, Nelson, Fox Mark VII and Cyclon) that have been run on 30 to 50 per cent nito. I was just hoping the turbine oil would work. Without positive proof that it will work, I will not take a chance.
Risilone: https://www.walmart.com/ip/Rislone-E...-9-oz/23598497
Turbine oil is fine I'm sure. Really, any oil is fine. Some just require repeat treatments a little more often. I use ATF with about 5% sea foam mixed in OR sewing machine oil. Neither one dries out - though the ATF mixture minimizes carbon superbly.
Sounds like a good choice.
Dennis
Dennis
The air tool oil is good to use. The regular marvel mystery oil isn’t so good. I use sewing machine oil or a mix of 90-95% Dexron ATF and 5-10% Seafoam. Either works well and is extremely cheap.
Michael
Whats wrong with the regular MM Oil?
Jim
Marvel Mystery oil, air tool or otherwise is merely Stoddard solvent (mineral spirits) and light naphthenic oil with, it seems, a bit of peppermint oil. It runs off of metal surfaces very quickly.
Wish I had taken pics of the Saito 120 I just rebuilt. Looked like someone had painted the inside with red paint! The owner had used Marvel Air tool Oil religiously and generously.
Air tool oils are not in the same world as penetrating oils. Crap like regular MMO and WX40 are worthless for the reasons already listed. Automotive oils such as ATF, motor oils, power steering fluids, etc. are engineered and used for their purposes because of their ability to resist/prevent corrosion, lubricate, help cool (by preventing friction), etc. DUH. Would you use air tool oil or MMO in your car or trucks engine? Transmission? WD40? I sure as hell wouldn’t.
