How much power can be restored?
I have several thunder tiger .46 airplane engines,they all ran good before,Just as they getting old,The compression lost gradually.I wonder if change their piston and sleeve how much power can be restored?
Any body would like to share you experience? Thank you.
TX
I would not worry to much if the pinch still exists at the TDC. As the engine warms up, it will expand and the clearance will not be a problem. Just make sure you have some Castor oil in your fuel and you are good to go.
