Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
HELP PLZ....ROSSI 53 CARB replacement
Old 07-29-2018, 03:15 AM
bikz
Unhappy HELP PLZ....ROSSI 53 CARB replacement
broken (and bent) high speed Needle assembly
Dear brethren,
I crashed my fav Stik today which had the brilliant Rossi 53 two stroke engine......anyway, my carb got damaged.....not the entire carb but the part which is bronze in colour which houses the high speed needle and the fuel in nipple (the part on the right of the photo)...
Two questions:
1) Can the part which got damaged, ie the bronze part alone be replaced? If so, plz point me in the right direction to purchase one.
2) I have come across Irvine and Perry Carbs but have no clue which part/carb in either brand would fit this engine. Plz guide me. (can the part in question 1 above alone be purchased ?)
Thank you and all help is greatly appreciated....i love this engine and want it running again.......
Old 07-29-2018, 04:24 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
You’ll probably need to search eBay and the engine forums that get more traffic. The engine forum on RCGroups gets a lot more traffic, you might try there. Rossi parts don’t come up for sale often, but while engines do.
I’d measure the O.D. Of the neck of the carb that fits into the engine, and measure the I.D of the barrel and add that info to any other posts you put online. Perhaps Rossi used the same carb on more than one engine size, so it will help others to help you.
Old 07-29-2018, 04:41 PM
bikz
the damaged high speed needle
i have not been on the Forums of any kind in a while to be honest.
thanks for your reply.
RC Groups is a separate forum, correct? i have searched on E bay but nothing has turned up except for complete engines for sale!!
Old 07-29-2018, 05:21 PM
1QwkSport2.5r
eBay can be hit and miss on parts for old engines. Sometimes it’s the only place you’ll find old and hard to find spares for old engines long discontinued.
You can try RCGroups.com.
Old 07-30-2018, 10:02 AM
the Wasp
my link here may help you find a different brand Carb that will fit your Rossi engine, or you could buy one from MECOA, that is if you want to order from the USA
the chart tells the Neck OD and ID
http://www.mecoa.com/acc/carbs/index.htm
Jim
Old 07-30-2018, 11:06 AM
Jesse Open
Jesse Open's Avatar
Two possibles If I can get decent dimensions from those remains, I can probably make a replacement.
Second, I have a Super Tigre carb that is probably adaptable; either by turning the O.D. down or fitting a bushing.
Let me know if you are interested.
