YS FZ115WS with MAP Mini Air Trap
My Feedback: (50)
Some information for all the bored people stuck at home. MAP Mini Air Trap is working great with YS FZ115 WS. I mounted my YS on a .60 size ultra stick and I was limited to smaller tank 14 ounce instead of 16 ounce that I wanted to use. On first couple of flights I also noted some air bubbles probably do to not enough foam but space was limited. I decided to try air trap to eliminate air bubbles and make it so could drain main tank empty and have a little reserve. Its worked great. This combination of plane and motor is a blast to fly. Motor has APC 16x8 and turns it just shy of 10,000 RPM and with less then 1 gallon of fuel through its running great. Model Aviation Products was great to deal with. I emailed them that saying I wanted to use there product with glow fuel and they said sure no problem just have to change out a o-ring.
