Info on nitro engines
Old 05-06-2020, 07:43 AM
JONTY3
Default Info on nitro engines
Hello was wondering if anyone has some good info wanting to replace my Thunder Tiger Pro 15 engine with something modern ?
Or am I wasting time so be better buying a new model.. had my 1/10 scale thunder tiger escort cosworth for 25 years and dont want to part with it if possible.. cheers
Old 05-06-2020, 12:42 PM
the Wasp
I don't know much about those smaller engines. the engine links I posted for you are all older engines that you can still buy.
out of the ones I posted> if you want a high grade engine buy a Fuji or an HP, their .020 size are $180 and $200. <they are Old School quality engines! Fuji's are real pretty engines. if you want a good cheap engine maybe buy the K&B .020, or one of the others I posted.
if it must be a modern engine as you say go to Towers and Horizon and look around. see the bottom 2 links.. but if you go to RCGroups and join up you can get a lot more info.
hold on, more people may reply with better info.
RC Groups,
https://www.rcgroups.com/forums/index.php
Fuji,
http://www.mecoa.com/fuji/index.htm
HP,
https://www.mecoa.biz/shopdisplayproducts.asp?id=41
K&B,
https://www.mecoa.biz/shopdisplayproducts.asp?id=22
http://www.mecoa.com/rjl/c15/c15.htm
Shuwa Industry - TOKI engines
http://www.mecoa.com/mecoa/15/1501.htm
Horizon,,
https://www.horizonhobby.com/
Towers,,
https://www.towerhobbies.com/
Jim
Old 05-06-2020, 01:07 PM
JONTY3
Hi Jim thanks for info much appreciated I will look through see what’s worth doing as if be expensive will prob by a new model lol. Seems you can get bits easier from abroad than here and cheaper..
regards
Jon
Old 05-06-2020, 01:28 PM
JONTY3
Also not sure if will need new clutch, flywheel and clutch bell as not sure about what will cost what ..
Jon
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
