OS 65AX Liner Issues
Old 05-15-2020, 06:42 PM
thailazer
thailazer's Avatar
Default OS 65AX Liner Issues
I picked up a used 65AX recently and it looked pretty good so I put it on a plane and flew it today for four flights with good runs each time. I noticed a strange grey sludge in the exhaust residue and decided to tear the engine down when I got home. The engine looked very good inside except for two odd things: The liner has some of its electroplated coating chipped off on the outside near the crank as you can see on the photo. There also was an significant amount of blackish carbon on the long muffler screw. The engine has very good compression and the TDC squish is very tight, just like a new engine. I could not find any of the coating bits in the crankcase and am wondering if OS would use a defective liner like that as the defect is on the outside, not inside. The inside of the liner and the piston look great with no scratches or scuffs.
Old 05-15-2020, 08:23 PM
the Wasp
did you check the muffler to see if there is something in it ??
Jim
Old 05-16-2020, 03:48 AM
A. J. Clark
A. J. Clark's Avatar
That looks a little like rust. Maybe from the bearing if it's been setting for a while. Was the residue there like that every flight ?
Old 05-16-2020, 03:58 AM
thailazer
thailazer's Avatar
Wasp.... You might be on to something. If there was a mud dauber nest in there that would explain the debris. I didn't see anything when I took it apart except the blackish carbon on the long screw.
AJ...... The grey sludge was still coming out after the fourth flight. I thought it might be just old fuel, as normally I have a slight film of red from the fuel I use. At any rate, the stuff coming out after the forth flight was still grey and not red. I wiped the plane down after each flight watching this stuff.
Old 05-16-2020, 05:54 PM
the Wasp
can you take the muffler apart (like the older FX mufflers) ?
as for what AJ said, how smooth does the crank turn ?
Jim
Old 05-16-2020, 07:06 PM
thailazer
thailazer's Avatar
Jim
The crank turns fine and is smooth. The bearings look good. No bits of anything in the crankcase and the backplate is not scuffed. I did have the muffler completely apart and nothing inside but sludge and that blackish carbon on the screw inside.
Old 05-17-2020, 09:21 AM
the Wasp
well if there is a lot of sludge that could be the problem, clean it out well before the next flight,
some times with a new engine you can get sludge while braking-in.
what kind/ brand of fuel are you using ?
EDIT: and how did you tune it ? running too rich is almost as bad as running it too lean for a ring-less engine.
Jim
Old 05-17-2020, 10:39 AM
thailazer
thailazer's Avatar
Yeah, I am thinking it was past fuel residue left over inside the muffler. I cleaned out quite a bit and my bet is the prior owner used a castor based fuel. I am using Omega fuel and it has only a slight reddish tint so am hoping all looks normal after a good clean out.
I am just going to run the engine and see what happens as it ran fine. I did run it slightly on the rich side but not overly so.
The liner having part of it chipped away concerns me, and I guess OS has had issues in that area. Just glad it is on the outside and not on the inside!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
