What's the closest I can get to 30 size for marine glow engines? What about 40 size?
What's the closest I can get to 30 size (5cc / 0.3 cubic inch) when it comes to a good quality marine (water-cooled) 2-stroke glow engine that is currently or at least was recently manufactured? Also, what's the closest I can get to 40 size (6.7cc / 0.4 cubic inch)? Who makes any such engines? Thanks.
Although not a true marine motor, a Novarossi or Picco .28 is available with a heat sink head which could be converted or used as is. Truggy motors. OPS may still be available.
if you are not looking to spend a lot, here you go, you can get a 46 here in my link. even with a pull start.
but you better call before you order, because these engines are made to order and it may take a month to get it, if you want a more expensive engine ask about the K&B engines. they are well known
https://www.mecoa.biz/shopdisplayproducts.asp?id=11
Jim
Jim
