Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
Any issues with liner peeling on O.S. MAX-160FX (non-brass liner + ringed piston)?
Old 06-21-2020, 04:05 PM
BriKali
Default Any issues with liner peeling on O.S. MAX-160FX (non-brass liner + ringed piston)?
I've seen plenty of threads describing O.S. ABN (pre-ABL) non-ringed 2-stroke glow engines as having issues with peeling of the brass liner's nickel plating. I was curious if anyone has seen or heard this liner peeling issue extend to non-brass liner and/or ringed O.S. 2-stroke engines, specifically the O.S. MAX-160FX. It's unclear to me if the O.S. MAX-160FX has any sort of plating on its liner and, if so, what material this plating would be. But, if the 160FX's liner does have nickel plating like that which has caused issues on other engines, would the 160FX's non-brass (steel) liner and ringed piston make any peeling of a nickel plating a non-issue? From what I've been able to gather (please correct me if I'm wrong on this), the liner plating peeling issue seems confined to O.S. 2-stroke engines with brass liners, without piston rings.
Old 06-22-2020, 02:40 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The OS FX 160 liner appears to be all steel: https://www.towerhobbies.com/cgi-bin...p?I=LXUT10&P=7
Old 06-22-2020, 08:35 AM
rgburrill
rgburrill's Avatar
IIRC the purpose of the thin liner was to compensate for the difference in thermal expansion between the piston and the brass cylinder. It is not needed in ringed engines like the 160FX. The problem with nickel was because OS got cheap and replaced chrome with nickel. I've not heard of "ABL" since I quit using fuel some time ago. I don't think I ever had an ABN engine.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
