Info on Webra 61
Old 11-24-2020, 06:59 PM
johnverfurth
Default Info on Webra 61
Hello. I was donated an old Kalt Baron 50 Helicopter. First thing I noticed was the engine was locked up, so I decided to pull it for a thorough cleaning and bench test. The engine looks to be a Webra .61 Blackhead with a Dynamix carb and rear exhaust. The exhaust pipe has no nipple to pressurize the fuel tank. Is this normal? Im really new to glow engines and am unsure how to attempt to start it. How should I go about priming it and will it stay running without being pressurized?
Thanks! John
Old 11-29-2020, 06:44 AM
Hemikiller
My Feedback: (125)
Dynamix must be pressure fed, use pump or muffler pressure.
Old 11-29-2020, 06:46 PM
the Wasp
my advice is not to use that carb. see if a different brand will fit your engine. start with OS.
if you are going to fly that engine in a plane you may find a carb that will fit it in my link.
http://www.mecoa.com/acc/carbs/index.htm
Jim
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
