Tower Hobbies .61 Carburetor
I need a carburetor for a Tower Hobbies .61 which I believe, was made by
Asp or maybe Magnum. It's a two stroke engine. Please let me know if
you have one available. Thanks.
Super Tigre carbs are much better with its midrange adjustment.
What’s the neck size of the Tower .61 carb where it fits into the engine? I have a table of some of the engines I have and their respective carb neck size;
HB .61 - 13.5mm
GMS .47 13mm
OS .40SF 13.5mm
Enya 40CX 13mm
ST GS45/G51, Como .51 14mm
ST S25/S29 11mm
ST G60 Series X .60 15mm
TT.46 Pro 13mm
TT .61 Pro 15mm
Irvine .46 Mk II 13mm
Enya SS40 13mm
K&B .45 Sportster 13.5mm
K&B .65 Sportster 15.9mm
Enya .45 #6001 (2-rings) 11mm
HP .40 11mm
Jett BSE .35 16mm
Jett BSE .56LX 16mm
HB .61 - 13.5mm
GMS .47 13mm
OS .40SF 13.5mm
Enya 40CX 13mm
ST S25/S29 11mm
TT.46 Pro 13mm
TT .61 Pro 15mm
Enya SS40 13mm
HP .40 11mm
Jett BSE .35 16mm
Jett BSE .56LX 16mm
I have a TowerHobbies .61 with purple head.
It crashed something like 8 or 9 years ago and broke the carb neck.
For some unknow reason, I want to overhaul it and will need a new carb.
I had a SuperTigre that only became reliable after using a O.S. carb on it. Therefore, I believe that a O.S. .61AX carb would fit and improve the reliability of my towerhobbies engine.
Does anyone knows if there is another reliable carb?
I really don´t remember anymore how this one did perform.
Thank you
Mauricio.
Thank you
Mauricio.
Someone correct me if I'm wrong, but I believe your purple head Tower .61 was made by Super Tigre.
I'm not sure if any or all of them were made in Italy, or China? I remember it being rated as one of the
most powerful 60 size engines when it came out.
It is nearly new, since I flew like 7 or 8 tanks before crashed the plane...
Mauricio
