OS FS-61 Slowing and/or stopping when remove Glow igniter
Hi folks,
I just test ran an OS FS-61 which I recently rebuilt and it starts right up (yayyy), but I cannot get it to run below 1/3 throttle without a glow igniter connected.
OAT is about 22-27F, and I'm running 15% Nitro fuel with an OS Type F plug and it seems to have reasonable compression.
Could it be that it's so cold that the plug can't maintain its heat? I've tried playing with the slow mixture, but haven't been able to appreciably change things.
Any thoughts?
Matt
Any thoughts?
Matt
My Feedback: (54)
Thanks all, I do know RPM will decrease without the igniter. In my experience, however, the reduction in RPM is around 10-20%, not 50% or more.
Perhaps I didn't make my initial post clear: this is abnormal behavior. Not normal.
What *is* new to me is operating a glow engine in below freezing temps. Hence the question: could the low temps be responsible for cooling the cylinder head to the point that the glow plug is unable to maintain a temperature sufficient to sustain combustion?
So the question stands. Any ideas?
My Feedback: (54)
I would try to keep the fuel warm inside your house before going to the field. Insulate the fuel jug to keep the fuel temp higher. Maybe go up in nitro. Try a "cold" plug, but it needs an idle bar. It's been too long since I ran a glow engine close to freezing, let alone below freezing.
Yup, patience is a virtue... and it would be nice to wait until Spring, but my kids and I are excited to fly this big, light, high dihedral bird (it's school vacation here in New England), and we bought some skis for it, so it's perfect weather... to us! The OS 61 is just right for put putting around at 1/4 throttle and just having a nice day out.
Our other plane is a high wing-loading T6 Texan with teeny weeny retracts which needs a perfect landing every time, or the retracts will bend... :-(
