Du-Bro Prop Nut Spinner - Dumb Question
What's the correct way to install an aluminum prop nut spinner onto a glow engine's drive shaft? I screwed one on to an O.S. 46LA and tightened it down by putting a drill bit through the hole in the front, using that for extra torque. The nut felt very snug when I finished, and the engine turned fine when I rotated the prop. But when I put an electric starter to it, the nut twisted right off and spun like a top on the ground. I'm guess I'm not too surprised that happened, because I suspect I'm missing a step somewhere. Any advice?
I am using a washer between the nut and the prop, but I can't imagine that has anything to do with it. The prop hub is pressed against the drive hub.
Good question if you haven't been there before. First a good drill bit is too hard for this job, because it will snap and break before you get the spinner nut tight. My quickest go to tool is a allen wrench suitable for 6/32' screws. My second go to tool is a 1/8" piece of "music wire" like landing gear wire. Your rod, or allen wrench should be at least 6" long, more is better. When you have the spinner nut snug, grasp the propeller, and tighten as tight as you can. In the past I have broken wooden propellers, (and that might have been a good thing!) but I've never broken a fiber filled nylon prop (APC, or Master Air Screw). If your starter continues to loosen the spinner nut, just tighten it a little more. Good luck, and let us know how things work out.
gpschult (09-28-2021)
706jim said he used a 7/8" box wrench on a round spinner nut? I guess he must file, or grind a hex pattern on them? The old Harry Higley safety prop nuts had a hex pattern, as well as a hole for a rod to tighten the nut. I've not seen any of the DuBro prop nuts with a hex, but that could be a more recent design?
It's been several years since I bought these prop nuts. At the time, all of mine were made from 7/8" hex bar stock, so the 7/8 wrench was the logical way to tighten them. If they are now completely round your best bet would be channel lock pliers with rag wrapped around the nut to prevent marring them.
Hi!
I make my own alu spinner nuts! I have used drill bits or any other round 3.6mm steel rod to secure them without any getting loose when using a electric starter.
See to that the engine isn't filled with fuel when you try to start. Flipp it first a couple of times!
Thanks Jan, for backing me up on that, (no fuel in the engine), no need for prime when using a starter.
Nice prop nuts, I haven't tried that on on my lathe yet.
