Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
Crockpot antifreeze cleaning recommendations
Old 12-03-2021, 08:44 AM
GlowKC
Default Crockpot antifreeze cleaning recommendations
Just a quick question for you experts. My car uses decks cool for general motors and I keep some of that on the shelf usually will that work in the crockpot to clean engines? Or do I need to buy normal antifreeze
Old 12-06-2021, 07:27 AM
1967brutus
You want the undiluted antifreeze, not the ready to use coolant.
Steelhead13 (12-20-2021)
Old 12-06-2021, 10:54 AM
GlowKC
Will Dex cool work as well. I run GM cars.
Old 12-06-2021, 11:05 AM
1967brutus
Doesn't matter what you run. Coolant is not antifreeze. It is about the straight undiluted antifreeze.
Old 12-07-2021, 08:26 AM
aspeed
aspeed's Avatar
I always heard the old type is what to use, undiluted, and I have used that. It is green, not the Dexcool Chevy stuff. Not the new OAT or HOAT stuff for sure. I don't use it any more though, just the Dawn or Dollar Tree concentrated LA Totally Awesome stuff. I think the heat from the crock pot is not worth the trouble except on carboned up mufflers.
Old 12-09-2021, 03:28 PM
1967brutus
I still use it for engines that have been messed up by Castor residue, but it is a job for the patient...
I use an old deepfryer, with temperature control.
Old 12-12-2021, 05:24 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Green or universal yellow antifreeze, undiluted, and LOW LOW LOW LOW heat!!!!!!!! Dexcool is garbage.
Old 12-13-2021, 01:59 AM
1967brutus
Buy the cheapest low-tech deepfryer. They usually have excellent temperature control down to 70 deg C (158F)
Old 12-14-2021, 05:52 AM
Jesse Open
Jesse Open's Avatar
Yes, quite correct. The Dexcool is a totally different animal and quite ineffective.
The Ethylene Glycol, greenish-yellow Prestone type is the stuff to use.
The Totally Awesome comes in to flavors as well. Use the original yellowish stuff, DO NOT use the newer, orangey stuff.
Old 12-14-2021, 06:09 AM
Jesse Open
Jesse Open's Avatar
The Totally Awesome comes in two flavors as well. Use the original yellowish stuff, DO NOT use the newer, orangey stuff.
I have always used Totally awesome in a heated ultrasonic cleaner, not a crockpot.
Old 12-15-2021, 08:04 AM
GlowKC
Ended up following ALL your advice, bought the Preston concentrate and the totally awesome. Both are great. Used the totally Awesome cleaner in my ultrasonic for some super fast and through cleaning. Crockpot takes hours. The Totally Awesome cleaner lifted the blue paint off my high compression button head from the Evo 46NX in seconds. It looks good though as it had a few chips.
