spare parts
Old 12-22-2021, 04:58 AM
daniel711
Default spare parts
Hi guys
I am in search of cilinder, ring and piston of my ASP 61 4 Strokes, canīt find this in any place.
Can somebodi help me?
My engine is not used, but i buy this 20 years ago, a few days ago, unboxed, and the engine has not compression.
Sorry my english.
I write from Argentina
Regards
Old 12-22-2021, 05:21 AM
1200SportsterRider
1200SportsterRider's Avatar
You most likely do not need any parts. You just need to free up a stuck valve.
Old 12-22-2021, 05:34 AM
1200SportsterRider
Part # 52710 or part # 52713 will be stuck open.
Old 12-22-2021, 07:02 AM
daniel711
I disassembly the top and can see the valvs operate normally
Old 12-22-2021, 07:05 AM
daniel711
thanks a lot
Old 12-23-2021, 11:08 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Low compression of a ringed engine can just be the ring isnt seated yet (broken in). Perhaps a small squirt of oil into the cylinder and turn it over - it’ll probably feel a bit firmer. It’s not completely out of the ordinary for the valves to leak either.
Old 12-24-2021, 02:16 AM
Jesse Open
Jesse Open's Avatar
A little heat from a heat gun, along with that oil may help. You may have to open the valve cover and see that the push rods are still in place under the adjusting screws.
You should try to avoid disassembling the top end, beyond that, unless the valves are very badly stuck, and that is rare.
If the valves are free and properly adjusted, run it. Usually the first tank of fuel fres everything and restores compression nicely. Including especially a gummy ring.
Old 12-24-2021, 06:18 PM
the Wasp
opps, wrong post
Old 12-27-2021, 07:07 AM
706jim
When you see the complete parts list for one of these engines, you can appreciate how lucky we have been to get them for the price they were sold at.
Old 12-28-2021, 06:48 PM
the Wasp
sssh don't say that, they will raze the prices!
