RCV 120 SP props ?
Old 01-17-2022, 02:50 PM
SJN
Default RCV 120 SP props ?
Hi
I have got this brand new RCV 120 SP that I want to get running.
What size prop should I get ?
I have searched the internet, and I get everything from 18x10 to 22x18 props......a crazy gap.
I know that rpm should be at 500-5600 on the prop, but I dont have a bunch of high pitch props to test out, and they are very expensive to just go out and buy a few and try out.
I want to use it on a warbird, so it needs some speed. APC 18x14 maybe ?
I have bolted it on to my H9 Ultra stick for break in.
Old 01-17-2022, 04:04 PM
706jim
While I'm not sure of the best propeller size, you've done the right thing:
Photographed the engine before running it as it will never be this clean again!
I'd suggest 18 x 10
Old 01-17-2022, 07:44 PM
the Wasp
here you go,,,
Jim
RCV 120-SP
RCV 120-SP vs. Saito
https://www.modelflying.co.uk/forums...investigation/
Flying Sites - R/C Aero Portal - RCV ENGINES
Old 01-18-2022, 01:29 AM
SJN
Thanks, I have seen those. :-)
I was hoping for some practical experiance.....like " I have a spitfire and it flys great with a 18x14 prop "
But I guess not many fly these engines compared to the "normal" 4 strokes. :-)
I have an APC 18x10 in my prop stash, and will have to see what RPM`s I get out of that.
But thinking it must need a 14 og 16 pitch to get the plane moving when the prop speed is at half of the normal rpm.
Old 01-18-2022, 05:18 AM
Jesse Open
Jesse Open's Avatar
A very interesting engine. Quite a feat, making that right angle turn with power delivery in such a lightweight and compact package.
The gearing places some pretty heavy demands on available lubrication no doubt.
Old 01-18-2022, 12:51 PM
1967brutus
I think it'll be OK... my 10,5 kg FW190 did pretty well with a 10" pitched prop spinning 5600 RPM on the ground (it gained about 1000 RPM in the air).
Different engine (ASP radial) but comparable RPM, and quite a heavy bird...
Old 01-18-2022, 01:52 PM
SJN
Went to the local hobbyshop, and they had a APC 18x12, so I bought that. They also have a 19x14.....but will try the 18 first :-)
We will see how it works out :-)
