Castor stuck engines
pilot195 (03-27-2022)
Many different oils and solvents work well. Heat is the element that does the real work. Heat gun, propane, toaster oven etc.
A good soldering gun is very helpful for spot heating and freeing up gummed wrist pins, carb barrels etc. Especially carb barrels while still mounted in the plane.
My personal go-to oil is "Kroil" for most jobs For a solvent, Xylene solvent cuts castor better than Acetone, Laquer thinner etc. Just do not use solvents near open flames !
I use heat and acetone. Works well enough for me and fairly quickly too. Never tried Xylene. Might have to next time. Exotic sounding chemicals that I’ve never used make me a bit sketchy... Someone told me to use MEK (MethylEthylKetone) once, but after reading about it, I decided the risks weren’t worth it.
I like to use stuff I can use in my house where the risk of blowing my house up is low or nonexistent and my fingers won’t get frozen off at the same time.
For sure, when I was a kid one of the fellows in school was working on his minibike in the basement. Tipped over a cup of gasoline and burned his house down. I generally avoid aromatic solvents for gummed engines.
The Safety Data Sheets for solvents are the primary source for handling instructions. They should be followed closely. Ventilation is almost always a factor as well as avoiding skin contact and splashing into the eyes etc.
Xylene and Acetone are found in the paint department at the hardware store.
If I'm in a hurry heat works well if I'm not I find a good soak in fuel works well. All can be done outside no fumes in the house.
If you use Kroil look beyond the safety data sheets to the chemical fact sheets. I have used Kroil for years at work and at home there are some significant cautions in the chemical fact sheets that are not mentioned in the safety data sheets. Some of the chemicals are highly skin absorbable at all temp and when heated are even more toxic if you breath in the fumes. It is the best penetrating fluid I've used but please use it carefully.
For heat I had an old cheap portable bbq I set up outside, the one that uses those 1 lb bottles. 1/4 steel plate instead of a grill, set the motor on the plate and fire up the bbq. I have also used heat lamps and my latest is a repurposed powder coating oven from Princesses Auto. I have seen people ruin a motor with to much heat from a torch so I only use one as a last resort.
For soaking I find the last inch of fuel in the jug is likely to show signs of contamination so I save this in a marked fuel bottle to use as a cleaner/soaking agent. I open up the engine to let the fuel get to the internals and I try and pick a container and lid just big enough for the engine and pour enough fuel to cover the engine. A lid keeps the fuel from evaporating. Usually over time and gently working the parts the engine will free up.
Upon inspection if the motor is worth saving I install new bearings and seals the old stuff I feel is beyond the best before date.
Also be aware if you are using especially methanol-nitromethane based fuel for soaking; it too is highly toxic and the same measures regarding skin absorption and inhalation of vapors apply.
So many gummed up globs today are barely worth cleaning anyhow.
My Feedback: (29)
TX
Thats true, if the owner wasn't mindful enough to oil the engine after use then its probably in poor overall condition now. There are always exceptions, my experience is keeping me from buying a used engine ever again. They're seldom worth the cleanup hassle and bearing replacement.
Whatever you know about well enough to handle safely.
Heat is the main element, the oil and/or solvent is secondary.
"Freeing up" and cleaning up are quite different tasks.
Being gummed up is actually a good thing in my opinion. It means that the engine was run on a high castor content fuel and is likely to be well preserved. If you are throwing out an engine because it is gummed up please send it my way. I will pay shipping.
Too late, I tossed out over 30 bound up two strokes last fall. Many never saw castor. Pity so many people are under the impression that castor is the only possible cause for a stuck engine.
Not that I don't know how to free them up, not close. Just don't have any use for them after taking the effort.
The value of used engines is going up. They sell for enough on Ebay to make it worthwhile selling them.
I agree with you more on 4-strokes. There is a lot to go wrong with 4-strokes and parts are costly if available at all. 2-strokes, especially bushed 2-strokes, are almost bullet proof.
Well I freed up this K&B .61 just using gasoline out side. I pulled
the backing plate and let it soak overnight. Then I used some
pliers and broke it loose... once it was loose I spun it with an air
ratchet and soaked it some more. I think the castor keeps the
internals from rusting. Then I blew it out and flooded it with oil...
I'll blow out the excess oil and put t back together... It should be OK.
Just the opposite here. I will expend time and money to restore four stroke engines. Two strokes for the most part are not worth either/or. Around here, with a few exceptions you can barely give a running two stroke away forget that if it needs work. Ebay has become a monster time and money waster.
I have given away a few engines here like Super Tigre 90, OS and a few Webra. But the stuck ones go in the trash regardless the make.
Jim
I sent that Italian Super Tigre 90 over to Okie, after I first offered it to you.
Sent Dave the Como 40, I think there are a few Webras still out there to check out.
Are you really interested in the frozen ones too?
PS (Edit)
Here are a few bits that didn't get tossed yet. An Enya 19v and a Webra 3.5 . Both turn over .
Let me know if you want them. Probably not made in China LOL!
A lot more to go thru so there will likely be quite a few more.
PM me your email and we can skip the $&@/:;(@
If you want the stuff, I will send it. You can believe that!
"Art" LOL !!!
If there was a choice to throw a frozen stuck engine in the trash or add it to the collection, I would add it to the collection without any question. I’d offer to pay shipping too. I love stuck engines.
