What carburetor is needed for a OS max 40sr. And where can you get them.
I recently acquired a OS max to 40sr verry cheep as it is missing it's carb. I have done some research but have come up blank. Does anyone know where I would be able to get a carb for it and if the original type is not available anymore what I could use as an alternative.
The 40 max used a 4A carb and the 40FSR used a 4B and a 4BK. The 4BK was a replacement for the 4B. There's is probably a Perry carburetor that could be used . I wouldn't know the specific one.
if you want to fly it and are not worried about having the stock carb I would find out if an AX 40/46 carb will fit it and use one of those.
or you can find a new carb (air bleeder) here in this link. scroll down a bit.
mecoa.com/acc/carbs/index.htm?id=26
Jim
Jim
Jim
Jim
