ASP 91 ABC Piston
Old 03-01-2023, 06:26 PM
Backyardhobby
Default ASP 91 ABC Piston
Would anyone know where I could get the internal parts to rebuild an ASP 91ABC engine?
Old 03-08-2023, 04:07 AM
1967brutus
Try "Mikegoesflying".Mike Goes Flying - We Fly Radio Control
He was the Magnum distributer as far as I know and might still have some old stock. Magnum is rebadged ASP, and identical in every practical way.
But it could prove cheaper to just go look for a used good ASP/Magnum .91 if you can find one.
Old 03-08-2023, 07:28 PM
hellcat 1
I believe that ASP engines and Magnum engines were the same internally. https://www.mikegoesflying.com/ is the Website that has parts for Magnums. He has a sleeve and piston for Magnums there
Old 03-08-2023, 11:50 PM
1967brutus
I have several different types side by side of each, and can confirm they are identical engines with minor cosmetic changes and a different badge.
At least, the later versions. The earlier versions (pre-2000), not 100% sure, I do not have "couples" of those.
