OS 62V 4-Stroke - Muffler Pressure for Tank ?
I always use a sacrificial inch of fuel tubing for the connection to the muffler, so in case it burns away I do not end up with a shorter and shorter pressure line. I connect the sacrificial piece and the pressure line with a simple straight piece of 3 mm or 1/8" brass or alu tubing (whatever I have at hand). Never comes loose. The pressure is only around 50 mbar (0.7 psi) anyway, and that is nothing.
BalsaBob (03-18-2023)
Several people at our field using those OS mufflers. Seems some have had the libe slip off.
Easy enough to be more certain it does not. Daves suggestion to trim and tap for a standard, barb fitting is a tidy solution. I have also seen a wrap of .01 to .02" safety wire around the muffler body, then neatly twisted around the pressure line. Works well.
That loss of pressure can result in a badly timed flame-out otherwise.
Seems the folks at our field soon discovered those wire clips did little more than actually promoting the vent line to slip off.
Without the retention barbs the clips prove to be of little use. Probably better without them.
Other than that, very minor issue,those OS "V" series engines have become very popular at our field.
