Engine rebuild.
Old 04-20-2023, 09:54 AM
jr-dub64
Cool Engine rebuild.
You all were so helpful in i.d. ing my OS Max 61 V engine, I pose another question. Which is, what to use for a ring compressor when installing new piston rings in these glow engines that have rings ? Curiosity is killing me.
Old 04-20-2023, 10:16 AM
TheEdge
My Feedback: (788)
All I ever needed were my fingers.
Old 04-20-2023, 01:59 PM
A. J. Clark
A. J. Clark's Avatar
The bottom of the sleeve should be tapered to help compress the ring and get it started into the sleeve.
Old 04-20-2023, 03:47 PM
jr-dub64
Okay, thanks so much. John.
Old 04-22-2023, 04:52 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Make sure the ring gap is aligned with the locating pin in the groove. If you don’t, you’ll break the ring in short order. Use lots of oil on the piston and ring before inserting it into the liner. Don’t forget to dress the liner with 400-600 grit emery paper too.
