Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
Saito "Make-Over" O'Haul *Updated with Video!
Old 02-21-2004, 05:27 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Default Saito "Make-Over" O'Haul *Updated with Video!
I let my poor Saito .45 sit in a shed for 10+ years. So I decided to overhaul it and give it a "make-over" at the same time.
It went from this:
To this:
To this:
Along the way, I removed the casting ridges from the connecting rod; drilled and chamfered oil holes in the big and small ends; and polished the rod to remove stress risers:
"What's for dinner tonight honey?" Umm......baked filet of Saito!
Actually this is just a mock-up as I am still waiting for a gasket set and new valve springs. I already got new Boca stainless steel bearings.
Old 02-21-2004, 05:36 PM
RaceCity
RaceCity's Avatar
Default RE: Saito "Make-Over" O'Haul
DUDE!!!!!
That looks great!
'Race!!!
Old 02-21-2004, 05:42 PM
jsn
My Feedback: (8)
Very nice Kmot!
John
Kmot
My Feedback: (24)
Kmot's Avatar
Thank you!
Old 02-21-2004, 07:10 PM
Rudeboy
Rudeboy's Avatar
Nice...
What did you use for paint?
Old 02-22-2004, 12:48 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Nice...
Krylon rattle can.
Old 02-22-2004, 12:54 AM
Flyboy Dave
My Feedback: (21)
Flyboy Dave's Avatar
[sm=thumbup.gif] Well done....looks great.
Old 02-22-2004, 12:38 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Thanks Dave!
Old 03-03-2004, 04:58 PM
Kmot
My Feedback: (24)
Kmot's Avatar
It's hard to find the right parts for a .45 and the valve springs I ordered for it didn't fit so I had to use the old ones but apparently they didn't take a 'set' from sitting for so long so that's a non-issue now.
I just finished running it and it runs great! I used Powermaster 15% fuel; a Thunderbolt four-stroke glow plug; and a Rev-Up 12x5W prop. It tops out at 8000 RPM and with glow heat will idle steadily at 2500 RPM. This is measured with an old Royal analog tach.
ID:	107444   Click image for larger version
ID:	107445   Click image for larger version
ID:	107446   Click image for larger version
Old 03-03-2004, 05:25 PM
spuck5644
SAAAAweeeeet!
Is it just rattle can paint or is it powdercoat??? If it's paint, why was it in the oven?
Steve
Old 03-03-2004, 05:45 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Krylon rattle can. I learned years ago to bake my painted parts on low heat (about 225*F) for an hour. Makes the paint almost like powdercoat tough.
-Tom
Old 03-03-2004, 06:34 PM
Rudeboy
Rudeboy's Avatar
What kind of paint is Krylon exactly?
Is it something special, or just ordinary polyurethane or something?
Could you perhaps post a close up of the label on the can?
Old 03-03-2004, 08:45 PM
Kmot
My Feedback: (24)
Kmot's Avatar
ORIGINAL: Rudeboy
It's just everyday hardware store paint. Albeit good paint, but everyday paint just the same.
http://www.krylon.com/
Old 03-03-2004, 09:05 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Default RE: Saito "Make-Over" O'Haul *Updated with Video!
OK, for the prop nuts and gearheads who just can't get enough, lol:
http://www.rcpics.net/view_single.php?medid=25250
"Right click and save", it's a big 'un so broadband is the word!
Old 05-01-2004, 08:00 AM
DTB
My Feedback: (15)
DTB's Avatar
That 45 looks terrific. I did the same thing to my Waverunner Waveradier 1100 exhaust years ago. Your right, if you bake it for 1.0-1.5 hours, it becomes rock hard. The paint is still on there with no chips to this day. Can't tell it isn't powder coated.
What are the hp specs for the Saito 45. I have a new Saito 40 that I received yesterday. I have heard the 40 has a little more power than the 45, so I am curious as to how much. I know hp are just numbers unless you have the torque to back it up, but since both are Saitos, I figure I just wanted to compare the two engines.
Saito 40 = .65 hp
Saito 45 = ??
Thanks and great job on that motor.
**UPDATED**
I found it. The 45 has .7 hp, which is slightly more than the 40, but it weighs 130g more than the 40, so I guess that makes up the difference. Saito 45 weighs 430g and the Saito 40 weighs 300g. The 45 actually weighs more than the 56 also.
Still great job on that motor. I really like the RED scheme.
Old 05-01-2004, 11:11 AM
ZB50
kmot,
What de-greasing procedure did you use prior to painting? I have used carb cleaner spray then Chrystler orange engine paint before but your Saito looks great!.
ZB
Old 05-01-2004, 01:42 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Hey guys, thanks for the compliments!
I never knew the HP rating of the Saito .45 but mine is not the "S" version so it is probably less than .7 HP anyway.
As for degreasing, in the pre EPA days I used carb cleaner dip. The stuff they sell in Calif now is worthless and useless so I use brake cleaner and then hot soapy water.
Old 05-01-2004, 02:07 PM
ZB50
One more question kmot,
Did you add a clear coat for the shine? I found hi-temp clear at the auto parts store and it made my Ryobi shine!
There is a few photos of it at www.jagengines.com , Look for the long john 120.
zb
Old 05-01-2004, 04:47 PM
William Robison
TomK:
From the sound, you have the valve lash set very wide. Crank then down to minimum, the engine will be a lot quieter, you'll have less wear on the valve train, and you'll pick up some more power.
I've run into the early and late valve spring problem too, for the mid size block engines I have made a cutter to go from the 6.95mm bore to 7.25mm allowing the later springs to be installed. You can do the same if yu ever want/need to. As the 45 is in the small block series yours most likely are a different size, but if they are indeed the 6.95 springs and the new ones are 7.25 I can bore yours. And the engine doesn't have to come apart, just the old springs off, bore, new springs on.
Bill.
Old 05-01-2004, 04:52 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Hi Guys,
No, I did not use anything extra. It's all just the Krylon paint.
Old 05-01-2004, 04:53 PM
Flyboy Dave
My Feedback: (21)
I thought I heard it "hammering" as well....
Old 05-01-2004, 05:11 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Yup, the valves were set loose when I did that test run. Better loose than too tight when you first run an engine is how I like to do it. I will be reseeting them before I fly it. Thanks!
Old 05-01-2004, 05:16 PM
William Robison
Tom:
I no speak joke. No matter how tight you think you have the valves set, if you can start the engine from cold they are not too tight. You will never burn a vlave in a Saito by having it too tight. If it's too tight it wont start - no compression. Set at zero clearance cold, the running clearance is about 0.002 due to the cylinder's heat expansion.
Bill.
Old 05-01-2004, 06:18 PM
ZB50
Bill speaks good words in last post! I have found that when the engine warms, the valve lash or click you hear, changes from when it is cold if the adjustment is a bit wide.. I have always kept the valve adjustment on the lower side of the spec. Read that as, don't allow any slop to speak of.
ZB
Old 05-01-2004, 06:31 PM
William Robison
ZB:
As I've said many times, I set mine at a half thousandth (0.0005").
And thanks for the back-up.
Bill.
