What .46 to .53 engine / brand
For my first motorplane (until now I just flew gliders....) I need a motor in the
range of .46 to .53.
I would appreciate some hints on the motor to buy.
What I was looking at was os, irvine, gms, mvvs, super tigre, fox, magnum.....
I would prefer an american or european made engine...
Thanks for your help
My Feedback: (50)
RE: What .46 to .53 engine / brand
Cannot miss with the Irvine-53, I have flown ALL types of airplanes with that engine and I am more impressed with every application!
Runs great on 0%-5% and is possibly the easiest engine to tune that I have had-
You may also look at the TT Pro-46, bang for your buck factor is high!
Good luck,
Good luck,
Well.. this has turned into an Irvine thread
so I also vouch for the Irvine .53 a veryu powerful, reliable, and all around great engine[8D]
CA
Make it 7 of 7 for the Irvine. Yeah, it'll cost a little more than some of the OS *clones*, but to me, it's worth every penny. Easy to start, reliable and powerful. You can't go wrong with an Irvine.
My Feedback: (102)
The Irvine .53 has the advantage of being a very tractable engine. You can use it as a hotrod with a 10x6 or 10x8 or put a 12x6 three blade or 13x6 two blade on it and fly well over 20 minutes on a 14 oz tank. The big props don't overload it nor do they make it run hot.
This is getting repetitous (joking) have 4 irvine 53s in the airplane stable
and a 46 (brain dead moment) should have gotten the 53 but still a great engine
WOOOOOOOOOOOOWWWWWWWWWW
think I HAVE to buy an Irvine .53 (and in fact I will, just have to find a good mail order source... living in Geneva our dealers do not even know the brand)
Thanks a lot for all your "votes" !!!!!
AZ
That was an easy decision :-]
Have you tried [link]http://www.justengines.unseen.org/[/link] ?
Paul and Jenny are great people to deal with.. I have ordered lots
of Irvines from them and never a problem..
As mentioned above...
order from just enignes (www.justengines.unseen.org)
Chris,
Jenny speaks french, so you might be interested !
Hi everybody
The motor is already on the way from Just Engines
Looking forward to that powerplant...
Strykaas thanks for the hint (but I still talk better english than french, malheureusment [], originally coming from the swiss german part of switzerland).........
Hey Chris,
Did you see the 'collector' version of this engine is available ? It is black instead of maroon....
Stated : "Collectable 'Limited Edition' (200 in batch) Irvine .53...... (anthracite coloured casing)"
A bit more expensive, but :
1) Rear needle valve
2) what a look !
3) Prop nut included
2) what a look !
