Engine I.D.
Old 08-31-2004, 04:49 PM
still burnin
Default Engine I.D.
I was wondering if anyone could help me with a engine I.d.. I have not had a chance to track down a camera yet but thought maybe with a good definition it could be named. This is what I know. The plane was given to me and the person said they bought it at a show about 20 years ago but know nothing else. It has a K.B. stamped on the side of the motor under the exhaust side of it, so I know the brand. I can not find the engine size, there are no other marks on it. I do have a TH .40 and this engine is bigger than the .40. It has the same mounting specs. as some other .60/.61 sized engines. It is on a plane with a 54in. wing span. the engine runs but I think the crank is bent because the is a vibration in it a full throttle. I would like to know the size to see if there are any parts for it or what size engine I need if I have to replace it. Thanks Matt
Old 08-31-2004, 06:47 PM
Doug D.
Default RE: Engine I.D.
A photo would help the most. Maybe you could find someone to take the photo for you !!!
Old 08-31-2004, 08:14 PM
MikeSell
MikeSell's Avatar
If no size is cast in the case it is a sportster series. The .20/.28 appears the size of a normal .40. The .45 appears almost the size of a .60. The .65 appears the size of a .90-1.
They are a bushed engine. They do not like more than 10% nitro. If it is a .45, it should turn a 10x6 at about 13,000 or an 11x6 at about 11,600. The vibration you feel may be an unbalanced prop. Parts for this engine are still available at
WWW>MECOA.com
Old 09-01-2004, 05:20 AM
still burnin
Thanks for the info. It gives me a direction to go in.
Thanks Again
Matt
Old 09-01-2004, 07:49 AM
Sport_Pilot
Sport_Pilot's Avatar
Could the vibration be due to detonation?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
