What are you using for a fuel tank?
My Feedback: (38)
I have a YS.45FS and it sure pumps up that tank, the one I had leaked out the screw on cap for the fuel connection. Went to a different one now, need to test it.
Just wondering what works best. Also, what plug and fuel % is best in these?
My Feedback: (31)
YS Engines
John
YS Engines like 20%nitro/20% synthetic oil for sport use...
OS #8 plug or a Enya #3 plug works well.
Use a fuel tank that is of the seamless variety, so as to prevent a rupture. Sullivan offers these as well as others...
Tettra available from Central Hobbies offer's a tank inteneded for pressurized systems.
My Feedback: (12)
YS tanks
Some people recommend wrapping the tank with strapping tape to keep it from swelling under pressure.
And while the four stroke YS engines run well on 20/20, it might be a little high on nitro for a 45 2 stroke, especially if you are gonna run a pipe..are you gonna run a pipe?? If so you will need a cold plug for 20% nitro, IMHO.
I wrap the tank in strapping tape. I have a pipe on mine and run anything from 5% to 15% and use an OS#8 plug. This engine on a pipe with 15% can be/is hard on plugs. I can't recall seeing any difference in performance between the 5 and 15% fuel with a 10/9 APC prop.
I use the Tettra tank that is available from Central, like Michael said. I have used it for almost a year on my YS 91 with no leakage at all. Sometimes I forget to release the pressure when done flying and I get a nice fuel bath when I open the vent the next day. Good luck.
Bob
Bob
Fuel Tank...
John,
I have the YS-63 FS and I'm using a Sullivan tank as well. I wrapped it with clear packing tape since I've heard of them splitting. I run the Wildcat 4 fuel. The label says YS 20/20 on it.
I've hear excellent things about the Wildcat fuel. I've run it in there since the engine was new and I've had no problems with it.
Sideshow: I'm glad to see I'm not the only one to hose the place down by pulling the wrong line and from the pressure in the tank!
I have mine in a Ultimate and have the fill and pressure lines come out the bottom of the cowl. One is longer than the other so I can remember which one is which. I figured it'd be easier to remember if I related the tube lengths to the tubes in the tank. In the tank, the pressure is up top and the pick-up/klunk line is on the bottom. I made the pick-up line hang down lower, thinking it's lower in the tank. I still grab the wrong one by not paying attention, but I always have a way to figure how which line is which.
-Snaggs
-Snaggs
CA
Fuel Tanks........
To Everyone,
depending on the airplane-Jet or prop-I sometimes use soda bottles and regular r/c hobby tanks-have used everything from shampoo bottles to spray cans-btw-did you know that a sprite soda bottle makes a very good air tank for air powered retracts ?
Jackjet
Jackjet
My Feedback: (8)
Fuel Tanks
I have used every brand mentioned here so far and they all work. However, I have found that the best tanks, by far, are the Hayes tanks. These were previously marketed as Kraft tanks. I have never had one of these fail or leak a drop, even when used with a pressurized Y.S. system.
In the ducted fan jet world, many wrap their tanks with carbon fiber cord and hold it in place with CA to prevent bulging.
My Feedback: (56)
AIR TANKS?
A lot of good ideas here. And pop bottles do make good fuel tanks.
But - I have seen pop bottles used for retract air tanks explode BIG time! And I mean total destruction of the airframe of giant scale aircraft!
Just ask some of the TOC fellows that found this out the hard way a few years back!
CA
Re: AIR TANKS?
Hi RCRC,
I have'nt have one explode on me yet-I put 280psi in a sprite plastic bottle and it blew the lid off-but for normal use- I use 125psi and that seems to work just fine for me.Plus I can cycle the gear 15 times on just 1 air charge.
Jackjet
