webra .20 marine needle settings ??
Old 02-07-2005, 08:35 AM
Simoncarter1
Default webra .20 marine needle settings ??
Hi i recently got given a webra marine .20 (3.5cc) engine and the person who gave me it messed around with the carb needle settings and it doesnt run nicely,
does anyone know the correct needle adjustments for it to run?
ive tryed messing about a bit myself but im not much good with engines as i am a newbie to glow engines,
im running it on 10% nitro fuel and it has a 'racing' glow plug.
if anyone knows the correct needle adjustments i would br very grateful, thankyou.
Old 02-09-2005, 04:04 PM
crrcboatz
My Feedback: (34)
Default RE: webra .20 marine needle settings ??
Start with the low end at 2 turns out and the high at 7/8 of a turn or a click, maybe 2 more. It should be fairly rich, if not open the low end up 2-4 clicks more.
Regards CUrt
Old 02-10-2005, 01:19 PM
Simoncarter1
Dont suppose you could explain that in dumb kid terms could you lol
cheers Curt
Old 12-19-2005, 01:28 AM
jetpack
jetpack's Avatar
Is this the carburetor that you have?
ID:	372553   Click image for larger version
ID:	372554   Click image for larger version
Old 12-20-2005, 06:46 AM
Simoncarter1
hi no those are not the carb i have ill try get a photo of mine thanx anyway
Old 12-20-2005, 06:56 AM
NM2K
My Feedback: (14)
ORIGINAL: Simoncarter1
Yes, here are the needle settings:
Adjust the needles until the engine runs its best.
Glad to be of service.
Old 01-29-2006, 08:10 PM
jetpack
jetpack's Avatar
Simon I started a thread in the Glow Engines section on my Webra Speed 20 Marine motor, just thought you would like to know.
I have just finished restoring it back to new from years of storage and I have not run it yet, so I am still no help on the needle settings. The Dynamix carb is tricky to adjust but not impossible. There have been others that have had the same question, so do a search under "Dynamix" once your there, and you should be fine.
Dont be discouraged.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
