burnt out glowplugs
My Feedback: (30)
NJ
burnt out glowplugs
I have a torq 21 engine on my axis. It burns glowplugs. I went over a mud puddle and the engine died on me. I took the engine apart and cleaned it with alcohol and put it back together. It didn't start. I eventually tried a new plug and it did start up. Once the engine turned off I tried to start it again and my plug was bad. What could cause this problem. Is there still dirt in my engine or did I not re assemble it correctly.
RE: burnt out glowplugs
sounds like the engine is ruuning hot this is a problem in cars due to lack of cooling air you also may be a little lean try a cooler
heat range plug and maybe a little richer on the needle
