Everything Radial Engines
Old 02-02-2007, 12:06 AM
  #351
Ram-bro
My Feedback: (101)
Default RE: Everything Radial Engines
Congrats on your purchase again. For the onboard glow, I went with the unt that is being sold here on rcu. it is less expensive than the McDaniels on board glow system and simpler to setup. McDaniels was $130 the anderson unit I got was $75 including the batteries.I am using standard four stroke glow plugs OS #7 I think but I cant be sure from here. Realize I havent run my motor yet so take it for what its worth.
Old 02-02-2007, 12:17 AM
  #352
w8ye
My Feedback: (16)
w8ye's Avatar
The OS four stroke plug is the "F"
Old 02-02-2007, 12:36 AM
  #353
MarvinE255
My Feedback: (10)
The link no longer works and the parts list for magnum engines no longer has the 400 radial. ,Thanks anyway
Old 02-02-2007, 12:44 AM
  #354
w8ye
My Feedback: (16)
w8ye's Avatar
It worked at 10PM eastern
But apparently they don't want you to link to a search?
Just go to www.hobbypeople.net and do a search for magnum 400
It will come right up.
Old 02-02-2007, 09:01 AM
  #355
MarvinE255
My Feedback: (10)
Thanks, it worked and they do have sone parts for the 400.
Old 02-02-2007, 01:54 PM
  #356
Kmot
My Feedback: (24)
Kmot's Avatar
Seb: I started out using five brand new OS "F" four stroke plugs and proceeded to immediately blow them due to an ignorant move on my part. So, after that I installed Tower Hobbies two stroke plugs and the engine has been running beautifully on them. However, I need to keep glow power applied at all times or the lower cylinder glow plugs flame out. Understand though, I am only breaking in the engine and only have one hour on it so far.
For a glow driver, I started out using two 1.5V dry cells in parallel. I have since switched to a nicad pack of 1.2V cells all paralleled together.
Old 02-02-2007, 05:49 PM
  #357
the Gnome
the Gnome's Avatar
Kmot, I had the problem with "flame out" of cylinders on several engines and it seems to be caused by uncontrolled combustion due to too much load by a too big prop. In every case the problem disappeared after using a prop with une or two inch less diameter or inclination. The rpm rise was only 200 or 300 rpm, but the engines ran more freely and smothly, and had no more flame out with the glow plugs switched off.
Holm und Rippenbruch
gnome
Old 02-02-2007, 07:27 PM
  #358
Kmot
My Feedback: (24)
Kmot's Avatar
Was this during the break-in or after the engine was fully run in?
Old 02-03-2007, 03:12 AM
  #359
the Gnome
the Gnome's Avatar
It was during the break in and afterwards. I only run the engine at 2000 to 3000 rpm for the first one hour with the plugs switched on all the time. When I then try max rpm the first time, the phenomenon occured. I normally, if everything goes right, go flying the engine after two hours and I always could reproduce the effect even after break in. You can check if the engine has this, when You try colder plugs, if You can get higher rpm with the cold plug compared to OS "F", for example, then it's the point for sure. Once I could even eliminate the effect with colder plugs, it was with my Seidel ST 540. But I also use a smallr prop on this engine now, just not to torture it that much. I think it will occur on most engines which have high power output due tu high compression ratio.
I think it's worth to try, if Your engine has enough rpm safety to the recommended max rpm (for safty a minimum of 1000 rpm).
gnome
Old 02-06-2007, 06:28 PM
  #360
Cybertom
Cybertom's Avatar
ALERT! ALERT! ALERT!
There is a SMOKING HOT Seidel ST996 for sale on ebay. This one is one of the few that actually matches the claims of the seller and has never been run! It looks like it's been stored in a hermetically sealed chamber!
IF YOU GOT IT, THIS IS THE ONE TO SPEND IT ON...
[link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150089101478&ssPageName=ADME:B:SS:US:1]Seidel ST996 on ebay[/link]
ID:	615269   Click image for larger version
Old 02-06-2007, 08:13 PM
  #361
chasrb
chasrb's Avatar
Tom you had to put this up here...now I want it, don't have the plane to put in - yet .lol 5 more days till the bidding really gets going!
Old 02-07-2007, 02:28 PM
  #362
chasrb
chasrb's Avatar
Okay, here are a couple of new entries..
[link]http://www.rcshowcase.com/html/RCS/rcs250.html[/link]
[link]http://www.rcshowcase.com/html/RCS/rcs150.html[/link]
I was going to post the pictures, but the upload link seems to be dead.
The gas 4stroke radial is catching on!
Old 02-08-2007, 11:45 PM
  #363
Cybertom
Cybertom's Avatar
Chasrb,
My forecast is that the 4-stroke gas radial will dominate the market. It has and will continue to be the source of inspiration for many great 1/3rd scale airplanes yet to come. The RCS 150 is the one to watch.
PS,
I will send you one of the new DVD's.
Old 02-09-2007, 08:23 AM
  #364
chasrb
chasrb's Avatar
okay, so I had a little time to surf...here is another link to a site that sells the double row Seidel's
[link]http://www.top-collect.de/cms.asp?NoReset=1&Produktseite=2&H=5912&Produktkategorie=5912[/link]
Okay, this will never fly but oh my....
[link]http://www.top-collect.de/cms.asp?Produktseite=3&H=5916&Produktkategorie=5916&Artikelnummer=804654&PR=1[/link]
Sorry more I can't stop...
[link]http://www.top-collect.de/cms.asp?Produktseite=2&H=5914&Produktkategorie=5914&Produktkategorie2=&PR=1[/link]
One more and that's it you have to vist this site!
[link]http://www.top-collect.de/cms.asp?ID=151&Mode=Detail[/link]
Done, I need a shower.....
ID:	617055   Click image for larger version
ID:	617056   Click image for larger version
ID:	617057   Click image for larger version
ID:	617058   Click image for larger version
Old 02-09-2007, 01:53 PM
  #365
Kmot
My Feedback: (24)
Kmot's Avatar
ORIGINAL: chasrb
Me too!!! lol.......
Man, that is some nice stuff. Lord, I need to inherit a lump of money!
Old 02-09-2007, 02:16 PM
  #366
chasrb
chasrb's Avatar
Hey Kmot, do you know where the videos went of the double row Corsair from Ron Tom? Putfile says the link has moved..
Old 02-09-2007, 10:50 PM
  #367
Kmot
My Feedback: (24)
Kmot's Avatar
The one I uploaded is gone. But the original author has them on RCU Videos.
Old 02-10-2007, 12:53 AM
  #368
NM2K
My Feedback: (14)
ORIGINAL: chasrb
I'm thinking about holding out for a gasser radial. I just bought the Saito R3 1.70. What a magnificent work of art. I get off just by looking at it.
Has anyone flown the R3 .90 as yet? Is it strong enough to fly a .60 two-stroke designed model with aplomb?
Ed Cregger
Old 02-10-2007, 08:41 AM
  #369
NM2K
My Feedback: (14)
Late last night I finally made the decision to buy a five cylinder radial glow engine. While I was thinking of buying the ASP/Magnum engine for a while, I finally settled on buying an OS or Saito, both serviced here in the USA.
I went to the Tower site to look at the OS R5 again and what to my chagrin should I see? An over night $500 increase in the price. Go see for yourself.
http://www2.towerhobbies.com/cgi-bin...?&I=LXBY70&P=0
This is similar to what happened many years ago when the Tower Bunch obtained the OS distributorship here in the US. Over night too.
Ed Cregger
Old 02-10-2007, 10:12 AM
  #370
w8ye
My Feedback: (16)
w8ye's Avatar
The Saito 90R3 has about the same power as a Saito 65. Approximately 10,000 with a 13-6 APC
Old 02-10-2007, 01:13 PM
  #371
Ram-bro
My Feedback: (101)
holy cow with the OS price increase. Maybe it is worth it but in my opinion you can get 3 magnums for the price of 1 os.......who needs to service theengine when you can just replace it.....
Old 02-10-2007, 08:00 PM
  #372
NM2K
My Feedback: (14)
ORIGINAL: Ram-bro
No, it is not "worth it". This is disgusting. I'm really disappointed in Tower. They must be down to their last couple of engines and know that it will be a while before they are going to replaced. Or maybe they know that they won't be replaced.
Ed Cregger
Old 02-10-2007, 09:31 PM
  #373
blw
blw's Avatar
You don't have to buy them from Tower. I found one for $1494.99 at southeastrc.com. Chief Aircraft doesn't carry the radial.
Old 02-11-2007, 12:44 PM
  #374
riph
My Feedback: (26)
This shop in Hong Kong is selling the Magnum. I was going to buy from them but found a NIB from Jamaica. About $60 for 3 - 5 days Shipping.
http://cgi.ebay.com/ws/eBayISAPI.dll...7272&rd=1&rd=1
Old 02-11-2007, 12:48 PM
  #375
Ram-bro
My Feedback: (101)
that is still nearly twice as much as the ones several of us have bought on ebay.
