Everything Radial Engines
Old 03-12-2023, 09:28 PM
  #3901
cymaz
cymaz's Avatar
You don’t say if the Saito is brand new. If it is, it will give more rpm as it runs in.
Old 03-12-2023, 09:33 PM
  #3902
1967brutus
Concur, can easily be 500 to 800 RPM
Old 03-13-2023, 06:15 AM
  #3903
rowdog_14
rowdog_14's Avatar
Yes, forgot about that. It is not new but not a lot of time. If I remember about 2 gallons of runtime.
Old 03-20-2023, 12:49 PM
  #3904
Chumpy77
Hey y’all. Figured this might be a good spot to ask about an engine I am inheriting. It’s an O.S. FR7 420 Sirius. The gentleman who owned it only ground ran it twice. It has never flown. I don’t believe the engine will turn freely right now. I will go pick it up in May and find out. Any advice on how to proceed with it? I would like to fly it but cannot find a suitable kit or plan from my modest collection. Any recommendations? I would like to perhaps find plans for an Air Tractor 401, or Stinson, or Howard, or whatever, of the right size. It is about 10” diameter. Help?
Chumpy77
Old 03-20-2023, 12:56 PM
  #3905
RichardGee
My Feedback: (156)
RichardGee's Avatar
Chumpy77
I have a buddy in Florida with this same engine on a giant Westland Lysander.. I believe it is a Phoenix Models ARF.
Flies it very scale and fits the cowl like a glove.
You should be VERY careful about buying a used glow radial. IF the previous owner did not run it totally out of fuel then squirt lots of After-run oil and thoroughly work that through the engine, there could be RUST inside the engine.
Old 03-20-2023, 01:15 PM
  #3906
Linkan2
Hello all saito fa-325r5 now have the main needle from Saito fa-100.
I helped a friend with the same problem and they got better.
now I don't know how old your engine is!!!
Old 03-21-2023, 09:50 AM
  #3907
Chumpy77
Wow! Well I’m not purchasing it, literally inheriting it from my best friend’s father’s passing. I taught the man to fly R/C back in late 70’s. I am intending to open it up to inspect for corrosion. Thank you for the response.
Chumpy77
