Everything Radial Engines
Old 02-22-2010, 03:29 PM
  #1751
SJN
Default RE: Everything Radial Engines
looks very nice and clean/streamlined
Who wouldn`t want one?
Not radial, but here is the USB hub that you must own if you love engines
haha...denne usb hub må du have http://www.youtube.com/watch?v=Hu7YCBTP2g8
Old 02-22-2010, 08:16 PM
  #1752
Luna_Rendezvous
Luna_Rendezvous's Avatar
Hmmm O.S. radial... me want very very muchly
Old 02-23-2010, 08:18 AM
  #1753
Luna_Rendezvous
Seidel 7 pot glow available over at HobbyKing for a reasonable 1K, only one in stock be quick
Old 02-23-2010, 11:15 AM
  #1754
SJN
gone allready
Old 02-23-2010, 11:20 AM
  #1755
nilsreinert123
can the seidel be run on regular 15/15 fuel ? it is very difficult to buy methanol in Norway , (socialistic country )
Old 02-23-2010, 11:43 AM
  #1756
HornetFitter
HornetFitter's Avatar
Luna-
Thanks for the info on the Seidel!!!!!!!!!!!!!!! It is on it's way to Canada...
Anyone know if it comes with a glow driver, or for that matter if it has any accessories with it or available for it? An exhaust ring would be great too...
Old 02-23-2010, 01:09 PM
  #1757
kahloq
kahloq's Avatar
It does not come with a glow driver.
I was looking at the specs...so its a 69.5cc motor. So not much bigger then the ASP 400 5 cyl at 65cc. However, what I did note was the rpm difference. The ASP 400 specs list up to 9000rpms while the seidel lists 6000. Thats a big difference if accurate. However, the seidel can spin a larger prop.....at 26x8 comapred to a 22x8 of the ASP. Might be good with a 22x12 then on the seidel to get some speed????
Old 02-23-2010, 01:42 PM
  #1758
Kmot
My Feedback: (24)
Kmot's Avatar
Wow! That is the new India built Seidel. For $1000 US that is a killer deal for that awesome looking engine! The ASP FS-400 is only $100 less!
Old 02-23-2010, 02:12 PM
  #1759
kahloq
kahloq's Avatar
The ASP 400 is 799(when logged in), so $200 less actually. The Seidel is 999 when logged in.
Old 02-23-2010, 02:13 PM
  #1760
HornetFitter
I just sent an e-mail to Seidel to get some answers about the Seidel-UMS 7-70 radial engine...
If anyone can help out, please chime in...
Here is the e-mail I just sent...
UMS-70
Seidel-UMS Seven Cylinder Glow plug Radial Engine
Good day Mr. Seidel,
Please excuse any grammatical errors in the following e-mail. I have used a Microsoft language translator to convert it from English to German.
The reason for this letter is because I have just purchased one of your engines from Hobby King and I have several questions.
1. I was wondering if you have a collector type exhaust system available, or if you might know of one that is available?
2. Is there any recommended oil or lubrication for the rocker arms, pushrods and valves, as they are not enclosed?
3. Which glow driver do you recommend?
4. Is the engine covered by a warranty and can spare parts be purchased for it?
I thank you for your time and wish you the best.
Sincerely,
UMS-70
Seidel-UMS sieben Zylinder Glow Plug Radial-Engine
Guten Tag Herr Seidel
Entschuldigen Sie bitte alle grammatikalische Fehler in der folgenden E-mail. Ich habe einen Microsoft Übersetzer verwendet, um Sie aus dem Englischen ins Deutsche zu konvertieren.
Der Grund für diesen Brief ist denn ich habe eine der Ihre Motoren nur aus Hobby King erworben, und ich mehrere Fragen habe.
1. Mich ich wurde, wenn Sie einen Kollektor-Typ Abgas System zur Verfügung haben, oder wenn Sie vielleicht eines wissen, die verfügbar ist?
2. Gibt es eine Öl- oder Schmierung für die Rocker Waffen, Pushrods und Ventile, empfohlen wie Sie nicht eingeschlossen sind?
3. Empfehlen welche Glühen-Treiber Sie?
4. Kann das Modul, die durch eine Garantie abgedeckt und können Ersatzteile für es werden erworben?
Ich danke Ihnen für Ihre Zeit und wünsche Ihnen Erfolg.
Mit freundlichen Grüßen,
Old 02-23-2010, 03:15 PM
  #1761
Luna_Rendezvous
ORIGINAL: HornetFitter
Luna-
No worries, hope it works out well for you! Do report back with lots of pics and some data, keen to see what sort of performance its capable of.
Mike.
Old 02-23-2010, 07:12 PM
  #1762
AmishWarlord
AmishWarlord's Avatar
You might want to try Keleo They might be able to make a custom exhaust ring for you.
http://www.keleo-creations.com/
Old 02-23-2010, 07:26 PM
  #1763
HornetFitter
ORIGINAL: AmishWarlord
I looked at their website this morning and they don't list anything. There is also a statement that they are too busy to do custom work too. []
Old 02-24-2010, 11:16 AM
  #1764
MarvinE255
My Feedback: (10)
I have the same engine and obtained an exhaust ring from Sonnenhof-Modellbau. Excellent product and good service. Web site for their Siedel engines is http://www.sonnenhof-modellbau.ch/Ve...ngsmotoren.htm Hope this helps. Doc
Old 02-24-2010, 04:19 PM
  #1765
Felix Barrao
I have just recived today my ST 7-70 from seidel directly, ( after 3 months waiting!!). Great looking engine. Hope it works fine. I´m going to use this DC-DC converter for the glowplugs, ( 12 V to 1,4 V 30 amp max)
http://cgi.ebay.es/CONVERTER-DC-DC-1...#ht_3524wt_960
I have tried it with the seven plugs, and it gives an steady 22-23 amps with no problem, from a 3S lipo, ( than only draws about 3,5 amps).
Some pics of the "home made" glow driver
Regards.
Félix
ID:	1385970   Click image for larger version
Old 02-24-2010, 04:46 PM
  #1766
HornetFitter
Felix,
Does the engine come with anything other than the basic engine (glow plugs, tool kit, manual, exhaust pipes and collector, etc ? (pictures would be great). Is it the UMS 7-70 made in India?
Old 02-24-2010, 07:36 PM
  #1767
estradajae
Take a look at [link=http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=11028]this[/link]
Hobby king is going to sell Seidel engines!
Old 02-24-2010, 07:58 PM
  #1768
HornetFitter
Jorge,
Check out the last 10 to 15 posts...[:-]
Old 02-24-2010, 09:10 PM
  #1769
Dad_Roman
Dad_Roman's Avatar
Anybody hear back from SLEngines??? I havent.
Old 02-24-2010, 09:42 PM
  #1770
estradajae
OOOOOOOPS....
Should have checked first!....and should check it more often!...anyway!!...one day...one day!! I promise!!
Old 02-25-2010, 12:30 AM
  #1771
Felix Barrao
Felix,
The engine come in a nice wood box, with exhaust pipes, ( no collector ring) seven OS F glowplugs installed, wires to power the glowplugs and instruction manual, ( german and english).Yes, this is the UMS 7-70 made in India. It looks great, I can´t wait to the weekend to test it!!
Regards.
Félix
ID:	1386326   Click image for larger version
ID:	1386327   Click image for larger version
Old 02-25-2010, 12:52 AM
  #1772
HornetFitter
THanks so much! I hope you plan on providing us with some video of the run and subsequent runs too ...
WooHoo!!!!! I can't wait for mine to arrive!!!!!
Old 02-25-2010, 03:30 AM
  #1773
Radial power
ORIGINAL: Dad_Roman
Did you send an e-mail to moki italia or to the other address specified in the SLEngines website?
I could be wrong, but I think that I read somewhere that the owner of SLEngines is going to introduce one or two new engines (a 7 cylinder and a 9 cylinder) at the upcoming "Verona model expo" (march 6th and 7th). It could be that he's quite busy with the final preparation for the event.
Radial.
Old 02-25-2010, 03:39 AM
  #1774
Felix Barrao
Of course, maybe this weekend
Regards
Old 02-25-2010, 05:27 AM
  #1775
AmishWarlord
Twin Moki 150's got to love it!
http://www.youtube.com/watch?v=LP0-9...eature=related
