Everything Radial Engines
Old 03-07-2010, 11:49 AM
  #1851
Dad_Roman
Dad_Roman's Avatar
Default RE: Everything Radial Engines
So look very carefully at the right hand side of the lower pics. Some single cyl eng in a vise, looks like a 4 stroke pipe sticking out. Wonder if they are going to knock off some Seidel singles? (I sure would)
Old 03-07-2010, 03:12 PM
  #1852
AmishWarlord
AmishWarlord's Avatar
ORIGINAL: Dad_Roman
Around here we call them "Saitos".
Old 03-07-2010, 03:48 PM
  #1853
kochj
ORIGINAL: Felix Barrao
Sorry, inox pipe is stainless steel.
Regards.
COuld you show me some close up picts of the collector muffler??
How did you bend the pipe??
or was it already like that/??
Old 03-08-2010, 01:06 AM
  #1854
Felix Barrao
The pipe come from plumbing, they are bent ( 90º pipes) I only have silver soldered them. I will post pics.
Regards.
Félix
Old 03-08-2010, 02:13 AM
  #1855
kochj
Thank you....
Here is another plane to add to the radial engine plane list...
"The world of 1/5th scale warbirds has suddenly become very affordable with the launch of the new, big, Black Horse Corsair. At 90 inch span this is a serious size model, but by careful use of laser cut, balsa and ply components, weight has been kept down to an amazing 18 1/2lbs. This low weight allows the use of affordable 50cc engines that are becoming so popular now. Fit a 62cc engine an you have real performance in the vertical.
The outline has been kept as close to scale as possible to keep the classic look 'all Corsair' as she grooves around the sky in a manner that only big models like this can. Black Horse made sure that the gull wing angle was correct as the easy option was never a consideration.
Not only are the multi-section flaps true to the original, there are air operated, twist and turn retracts included complete with functioning oleo legs. These are items that are nearly always a major additional cost in many models of this size, not so with Black Horse, they're there as standard!!
For easy of transpotation, the individual wing sides can be easily removed.
The whole model is clothed in duarble Oracover covering, so she will retain her looks for many years to come. The use of Oracover means that damaged covering is easily and exactly matched by a visit to your local model shop.
Flying is so predictable and easy that you could even make her your first warbird. The stall is benign and she handles predictably and stabiliy at all speeds.
Specification
Wingspan: 2310mm (90.04in)
Length: 1750mm (68.90in)
Weight: 8.4kg (18.52lbs)
Servos: 9 Servos (8kg min on elevator/aileron)
Radio System: 6/7 Channel
IC Engine: 50 -62cc Petrol
THis is coppied from the other post, but what the heck....round cowled planes are the best...
ID:	1393283   Click image for larger version
ID:	1393284   Click image for larger version
Old 03-08-2010, 09:44 AM
  #1856
kochj
There is a 90" corsair comming from BH models...
50-70cc...
This would be a good candidate for some radials....
It has a 3-piece wing....
I do not think the ESM Corsair will...
Old 03-08-2010, 06:59 PM
  #1857
Cybertom
Cybertom's Avatar
Nice Fairchild PT-23 with Robart R780 Radial Engine. I thought I was the only guy other than Ziroli who actually flew a R780. This guy has the engine running really well.
[youtube]http://www.youtube.com/watch?v=-TAOh3kAn6A[/youtube]
Old 03-08-2010, 09:03 PM
  #1858
Dad_Roman
Dad_Roman's Avatar
ORIGINAL: kochj
There is a 90'' corsair comming from BH models...
50-70cc...
Mine will be parked here....... (my Navy sons Meister Corsair)
Old 03-09-2010, 12:23 AM
  #1859
Robert_Ellis
Felix,
What is the outside dimension of the engine - diameter? Trying to figure out whether it will fit. Great video BTW - sounds fantastic!
Thanks much.
- Rob
Old 03-09-2010, 12:51 AM
  #1860
Felix Barrao
The outside diameter of the ST 7-0 is 230 mm.
Old 03-09-2010, 01:43 AM
  #1861
Robert_Ellis
Thanks Felix. I read that number on their site but it seemed so small I thought it was the mounting bolt dimensions. Looks like it will fit easily.
- Rob
Old 03-09-2010, 08:35 PM
  #1862
Dad_Roman
Dad_Roman's Avatar
ORIGINAL: Robert_Ellis
Felix,
Thanks much.
- Rob
Yea, I did the math. In roundish numbers the 70 is 9.25 and the 90 is 10.30
Old 03-19-2010, 12:32 PM
  #1863
RHarding
I feel certain that this was covered someplace in this forum, but I just don't have the brain energy to go thru 74 pages looking. Lazy hu!!!!
I boought my first radial, a Saito 1.70 three cylinder to go in my PAC Clip Wing Monocoupe. I ran it on a test stand yesterday for 15 minutes. Looking at the engine from the front, the lower left cylinder is not firing. I'm using Omega 10% with an extra 2 oz. of castor oil added. Prop is a Zinger 16 x 8. Fire is from a wiring harness from a single D cell NiCd 5000 mAH. Checking the volts at each plug shows 1.29 at all three. An unusual amount of unburned oil is coming from the exhaust. I'm using the Kelco collector ring. The cylinder is cool. Compression feels ok. I don't have a compression checker. Any ideas on this?
Richard
Old 03-19-2010, 01:09 PM
  #1864
HornetFitter
HornetFitter's Avatar
Ensure the valve lash is set properly and the glow plug is not burnt out...
Old 03-21-2010, 08:40 AM
  #1865
Wulf
Wulf's Avatar
Anyone heard any times or dates when Hobby King will ship the Seidel 7-70s-I have one on order also.I sent them an E-mail with regard to this question but no reply as yet...
Old 03-21-2010, 08:54 AM
  #1866
Dad_Roman
Dad_Roman's Avatar
ORIGINAL: Wulf
Anyone heard any times or dates when Hobby King will ship the Seidel 7-70s-I have one on order also.I sent them this an E-mail with regard to this question but no reply as yet...
They give you a heads up when they come in but they dont give lead times on restocking. At this point I wouldnt even warrant a guess.
Best bet...goto thier forum and ask there. They have a couple of guys there that I believe work at the plant so they sometimes can get some inside info on stuff like this.
Old 03-21-2010, 06:17 PM
  #1867
kochj
I had sent them a email as well...
I don't want to repost the email..but it went like this:
[quote]ORIGINAL:
We are sorry for the inconvenience.Items are only reserved when your payment is verified.It is the same for PayPal and Credit Card.And then there will be a waiting queue for the item.You will get the item whenever it is restocked.
Regarding your request,we have checked it for you.We are sorry that we don't have an accurate ETA for the item.But it arrives to us every 21-30 days.Please keep checking our website.Once we have it,we will update.
Old 03-21-2010, 06:23 PM
  #1868
kochj
The part of this that I am a little confused is that....
1.They have NEVER stocked Seidel engines...so they can't be restocked....
2.could have at least answered to wether or not they have even Recieved them from UMS/seidel.....????
3. If they have are they in there wharehouse?
4. If not, when did UMS/seidel say when they would send them to hobbyking????
By the way .
Advantage hobby is having a KILLER deal on all there Saito engines....
Besically, ROLLING BACK THE CLOCK.... before they raised the price on the radials, twins ect...
1500$ for the 5-cyl!!...
I may get mine now.....
Old 03-21-2010, 07:05 PM
  #1869
HornetFitter
ORIGINAL: kochj
By the way .
I don't want to say you are lying, but.... I was the first to order the engine from Hobby King (their stock level was 1) and I received it a week ago. As a matter of fact, I di a test stand run on it today and it sounded PURDY!...
Vid and pix to follow...
Old 03-21-2010, 07:35 PM
  #1870
Dad_Roman
Dad_Roman's Avatar
ORIGINAL: kochj
By the way .
1. Yea they did. Stocked 2 and we know both the guys here that got them
2.Of course they havent recieved them..or they would fill current orders (BO's IE:yours)
3. Of course not.
4. Now THATS THE QUESTION. Seems like they sell something to feel out the market and then place a larger and larger order so it takes a while. Ive seen the same pattern with Batts, gas motors, etc. Ill bet they didnt order till those 2 sold (which was quick). Im curious HOW MANY they ordered this time......and of course I believe now we will know how long it takes the factory (India) to recieve an order and build the product for delivery.
Thanks for the heads up on the Saitos
Old 03-21-2010, 07:50 PM
  #1871
Luna_Rendezvous
Luna_Rendezvous's Avatar
ORIGINAL: HornetFitter
ORIGINAL: kochj
By the way .
And did you notice that they raised the price by $200 after you bought yours.
Old 03-21-2010, 07:52 PM
  #1872
Dad_Roman
Dad_Roman's Avatar
ORIGINAL: Luna_Rendezvous
And did you notice that they raised the price by $200 you bought yours.
Kinda weird but you have to sign in and add it to your cart and then its the 999 price
Old 03-21-2010, 08:11 PM
  #1873
Luna_Rendezvous
ORIGINAL: Dad_Roman
Are you sure about that
Old 03-21-2010, 08:22 PM
  #1874
HornetFitter
ORIGINAL: Dad_Roman
Yeah, it only took them a couple days to figure that they could easily get more for the Seidels'. Someone said that they got free shipping with the purchase of an additional item. I ordered a few more things and they charged me the regular amount. On the positive side, I did not pay any tax or Duty... Thought that was strange, seeing as the Sonic Tronics glow ignitor from the US cost me an extra 13.00 for tax and handling fees. Maybe I will have to shop in Hong Kong more often...
Old 03-21-2010, 09:40 PM
  #1875
Dad_Roman
Dad_Roman's Avatar
Yea ya got me
Had my chance.....muffed it[:@]
200 bucks pays for free shipping, parts , etc, yada yada yada
Looks like the 9 went up too without any sales yet
Anybody remeber what they first had it listed at?
