Magnum XL400 Radial
Magnum XL400 Radial
I happen to have magnum radial engine new in box never used. I want to prepare break it in but I need information.
It came without instruction book and I have no experience operating such large complex engine.
Does anyone have experience, comment, feed back about this engine?
I have several questions
1. What kind of fuel? some said all castor lub should be used. other said synthe/castor blend is OK, what is your opinion?
2. Prop size: The largest prop I have is 20x6 menzs wood. Is it large enough?
3. glow plug driver: Do I need onboard glow plug driver? I have several 3000mA NI-MH cells. How many cells should I connect in Parallel in order to get sufficient capacity?
4. Break in procedure: Can I do it same way for big single cylinder four cycle engine or are there different method for radial ?
Any help is appreciated.
Koji
Koji
RE: Magnum XL400 Radial
Jim, Thanks for your comment.
Castor blend fuel isn't readily available in my area. so I have to mix it myself. Could you suggest what percentage of castor should mix?
I'm using 18% all synth fuel for many years. Add 5% castor oil making 23% blend, Do you think it is safe for XL400?
As for size of prop, could you tell me what is good for break-in run?
Onboard battery: Do you mean 3 cells (in parallel) is minimum?
Koji
Koji
